Results 1 to 7 of 7
Thread: Is this a typicult CAS(crank angle sensor) fault
    VE Calais
    Dec 2010
    Default Is this a typicult CAS(crank angle sensor) fault
    I have the code 47 on my VS. Its been displaying the fault for a couple weeks now.
    Ive orderd a new CAS and hopefully should get here in a day or so.
    Ive had the car stall once or twice before but this is what happened 2day.
    The car stalled quite a few times, id wait a minute and would start fine. At 1 stage it wouldnt start so I poured some bottled water over the harmonic balancer.
    The engine started then there was like a squeeling noise that was on and off but constant, ie 1-2 quick squeels a second.
    I wondered if the metal contracted a little causing the CAS to slightly rub the harmonic balancer?
    Anyway the car then back fired, loud bang and cloud of black smoke.
    Drove another k, then back fired 2 times in a row another black cloud and engine stalled.
    I waited for 10 mins then the car started fine and I could drive another 20 mins to get me home and no further issues.
    Is this a typicult CAS issue, the back firing threw me. I wonder if the CAS is just telling the injectors to fire at the wrong time causing a fuel build up???
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Sounds like CAS. The backfiring would be the missing signal causing no firing at all. The unburnt fuel builds up, then bang, a back fire.
    The squeal would just be the fact that the belt was wet.
    Visit my Facebook page
    VE Calais
    Dec 2010
    Cheers thanks heaps.
    Hopefully the new CAS gets here soon and I can change it over.
    vs commodore
    Oct 2009
    Tamworth NSW
    When replacing sensors,try to only use genuine holden sensors.Ive seen a few cheaper brand sensors cause problems or not last very long,especially the cheaper CAS's available from ebay etc.Ive been caught out before with a new faulty CAS and have run into a few others that had recently been replaced and had failed again withing a few months.I just paid $120 for a new genuine CAS for my VS from the local holden dealer.They are more expensive,but at least they last a few years and are reliable.I could have got one for $50 probably,but its not worth it if it causes me to break down or if I have to buy another new one in 12 months time if it doesnt last.
    VE Calais
    Dec 2010
    What I dont get is if its just a sensor with magnets on it. I dont understand why they seem to be such a common faulty device.
    What is it that causes them to fail.
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Heat would be my guess (but don't quote me).
    I've had to replace them in every Commodore I've had, but for some reason I've never had to do it twice on the same car...
    Also, I don't think I've ever bought a new one either, they've all been 2nd hand from a wreckers...
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    i brought a non gen cas( lasted 3weeks) got a gmh cas 2years ago and still hummming along
    Quote Originally Posted by Brett_jjj View Post
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  1. Crank Angle Sensor
    By wiseman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-03-2010, 12:00 PM
  2. Crank Angle Sensor
    By Crofty78 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2009, 01:21 AM
  3. crank angle sensor?
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-05-2007, 09:23 PM
  4. crank angle sensor fault
    By shumway in forum V6 Development And Modification
    Last Post: 06-02-2007, 05:34 PM
  5. Crank angle sensor
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-07-2004, 06:06 PM
