so i have just installed a lvl 3 dash into my vs executive and turned it all on and everything works except..
1. was wondering if their were any settings i had to change?
2. when i was playing around with it its making a beeping sound every 3 or so minutes :S ?
3. when i pressed 'set' it comes up in the middle with 70.00 L tank where i swear i switched it to 60L
so what does that mean
cheers james
if nothings been changed from stock it should be fine, what kind beeping noise is it making?
okk its just some loud high pitch beep which beeps 4 times then stops for a while then beeps again
possibly hand brake warning, i havn't heard the overheat one so i dunno. Perhaps ask 88GreenVN i think he does a fair bit with clusters.
The set tank size is where you were with the 70. You set this in 1 of 3 modes on level ground and a full tank.
Distance and fuel flow default is 625. You change this number after filling up the car and you look at all the numbers on fuel used and so on.
and 3 Dangerous non ABS VN's
Beeping Codes from Level 3 Clusters
Overspeed A = T4 pause (1) T3
Low fuel B = T2 pause (1) T3 pause (4) repeated 5 times
Hot engine C = T1 pause (1) T2 pause (1) T3 pause (1) T3 pause (1) T3 pause (1) T3 pause (1)
Park brake C = T1 pause (1) T2 pause (1) T3 pause T3 pause (1) T3 pause (1) T3 pause (1)
Press remote B = T2 pause (1) T3 pause (4) repeated 5 times
T1 = 2560 Hz 1/8 sec
T2 = 3200 Hz 1/8 sec
T3 = 4266 Hz 1/8 sec
T4 = 6400 Hz 1/8 sec
Pause = 1/8 sec
ok so do i change the 70 or leave it?? cause i changed it to 60 as thats my tank size..
mmm ill have to listen to it tomoz again fair sure there was one beep and 4 quick ones :S
and its not handbrake cause the car wasnt fully on
ok had another look and it seems to be 6 beeps first one loud then 5 quick ones ... aldo ive notice the hand brake light isnt one and before i did the change over i have the engine light on and now i have nothing![]()
with the orange plugs behind the cluster would it matter if i had them flipped up the wrong way ??
nm solved the beeping noise was right had the orange plug ass about :S
"Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
My VS II Berlina Wagon
MY12 II SV6 Sportwagon
