i wan't to put a towbar on what is irs
what is the difference between a VS without irs and a VS with irs and is there a different towbar for each one if so how can you tell between the to of them?
what u got irs if so the rear mount of the diff the 2 bolts towards the front of the car are used for the tow bar
irs is independent rear suspension
non irs is solid rear axle solid rear diff
Towbars are different. They are not interchangeable. Depending on the brand of towbar, they pick up on different spots.
