Hi
I have found this manual conversion on ebay.
I have a question in regards to the ecu that comes with it.
Will this work with my Vr buick if he was running it in a Vs?
Here is the item
VN VP VR VS V6 commodore manual gearbox conversion T5 (eBay item 170593044419 end time 30-Jan-11 18:42:42 AEDST) : Cars, Bikes, Boats
97 WRX AWD
Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
Turbosmart dual stage boost controller
IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
BP98 safe tune @ 171.8awkw
You wont need that VS ECU, keep your ecu out of the VR and get someone to do a memcal tune to have it able to run a manual trans.
Yeah that will work in your VR
there also is a guy on ebay his username is TRX100 he does the computer coverted to manual + Wiring to short out
the reverse lights etc..
pretty reasonable price aswell also MAKE sure it is an 8 BOLT FLYWHEEL
If it aint there hard and exspensive to find
hope this helps
