Results 1 to 15 of 15
Thread: VR Commodore - Motor Ticking
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    Default VR Commodore - Motor Ticking
    Hey all,
    When starting my VR commodore V6 Auto ( Cold ) a loud ticking noise can be heard. But once the car warms up ( 10 or so minutes of driving ) it vanishes. also when i bought the car i notice the car virobrated a fair bit. im not sure if ive just got use to it or its stopped but it still worrys me.
    Ive sat there at the engine bay just looking and listening... first i thought lifters, so i topped it up with oil. Not a change.. not a little bit.. ive had someone say the timing? ( it does seem to miss here n there )
    once i get home and it cools down ill record the ticking noise and chuck it on youtube so you can all have a listen.
    Thankyou, Todd.
    Heres the link: http://www.youtube.com/watch?v=MvVJYIB1OaA
    Current project; VH SL/X known as "NFNSUS"
    Ready for a overhaul due to licence issues
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Mate it's probably just old / clogged injectors. Look at getting new/reco injectors fitted or get your current ones cleaned. Better off getting new/reco ones IMO. Made a HUGE difference to my car, VS ecotec and the injectors were rooted lol. Started easier, ran better, no more flat spots, new ones barely tick at all.
    93' Pov-Pac
    Jul 2010
    Quote Originally Posted by nathanVS View Post
    Did you see an improvement in power and/or fuel econ with new injectors?
    VR Berlina
    Mar 2010
    sa
    exhaust leak. the stock exhaust maifolds on vrs are prone to cracking and cause ticking when gold and goes away when they heat up.
    take it to an exhaust shop and get a free check over.
    VR commodore acclaim V6
    Oct 2010
    campbelltown
    Its probaly hole in exhaust i got my exhaust fixed and engine mounts done and doesnt vibrate one bit, most prob your engines mounts are ####ed and resting on something making your car vibrate thats my opinion considering i got it fixed 3 months ago hope helps
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    Thanks for the info guys. i just posted the Link to the youtube vid up in the first post.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by Bizmark View Post
    Yeah huge improvement. Could be exhaust manifold as mentioned but that will be a LOT louder than injectors.
    93' Pov-Pac
    Jul 2010
    Quote Originally Posted by VCnewb View Post
    Doesn't quite sound like injectors to me, sounds like a larger item, though I have no idea what. Do you know which area of the motor the noise is coming from?
    I think i have noisy injectors, as my ticking is lighter and more rapid. I'll grab a vid later on so you can have a listen and compare to yours
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    I haven't watched the video yet, but ticking could be cracked/leaky exhaust or sticky lifters. Got oil in it? try topping that up / servicing it.
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    Yeah ive done the oil. no diff.
    I took it to a friend that knows a bit about cars and he said its lower in the motor?
    and that i wouldnt be able to find out what it is unless i pull the motor apart..
    so thats a last resort lol.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    I guess you could check your engine mounts, belts, tensioner, pulleys, etc. Anything that could be moving around and creating the noise. When the engines running grab a stethoscope.. or if you're not a doctor grab a screwdriver and put the handle to your ear and point the tip towards an area and have a listen, this should help focus your ears on the part of the engine where the screwdrivers pointing.
    see if you can pinpoint where the noise is coming from.
    93' Pov-Pac
    Jul 2010
    VH SL/x - VS BT1
    Oct 2009
    SA, Port Lincoln
    It has a slight miss here n there?
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Eh probably just old plugs, leads, coils packs, fuel filter, fuel pump, injectors etc etc.
  15. #15
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Hey all,
    Thankyou, Todd.
    Heres the link: YouTube - VR Commodore - Motor Tick
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  1. Ticking noise VN motor
    By kapzi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-08-2010, 12:34 AM
  2. vp motor ticking
    By mikky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-04-2010, 02:45 PM
  3. motor ticking noise
    By creamy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-06-2008, 12:50 PM
  4. motor making ticking sound
    By TINYTIM in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-06-2006, 09:47 PM
  5. Ticking sound in motor!
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2005, 09:06 PM
