Results 1 to 8 of 8
Thread: vs steering wheel help
    1996 VS acclaim
    Nov 2010
    townsville
    Default vs steering wheel help
    hey guys my steering wheel is on a bit of an angle every time i drive it. if i hold the wheel straight it pulls to the left. would that just be in need of a wheel alignment or what? thanks.
    honey dont let them snappin turtles bite yall eyelids.
    EH Holden, VS Ute
    Nov 2008
    if you let got the wheel that the car remains straight then in most cases (most) you can assume it is not the wheel alignment..
    after you have a wheel alignment and the problem remains then take the steering wheel off and relocate it to suit...
    wheel alignments are cheep, you should start with that... although the easy option would be just to remove the wheel and relocate it...
    my ute was doing the same, i put up with it for a few weeks because i knew a wheel alignment was coming... after wheel alignment it was better but i still moved the steering wheel now is perfect.
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Mine does this too, it's had wheel alignments and everything. I wouldn't think you'd have to relocate the steering wheel from the factory position though.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Moving the steering wheel is not the correct way to do it as it moves the rack off centre and it affects your toe out on turns. (Have you ever heard a car go around a tight corner slowly but the tyres were squealing?) If your steering wheel is crooked after a wheel alignment, the rack is not centralized. The correct way to do it is to set the wheel to the straight ahead position and adjust the tie rods until the wheels are straight.
    On most cars, to get the wheel straight and the front wheels pointing straight ahead, you need what is called a compensated (or thrust) wheel alignment, this adjusts the steering perpendicular to the thrust line of the diff.
    On vehicles with rear toe adjustment a full four wheel alignment is necessary.
    Visit my Facebook page
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Right, so we just need to go to our tyre shop and ask for the most expensive wheel alignment?
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    +1 to this. (except the toe out on turns bit. This comes from the angle of the steering arms)
    Quote Originally Posted by nathanVS View Post
    Just ask for a standard alignment and tell them the wheel is not straight.
    They still should fit the rear cameras to check the thrust angle, as stated above.
    EH Holden, VS Ute
    Nov 2008
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by RX25SE View Post
    Which are connected to the rack. If the one tie rod is shorter than the other it will pull that wheel in further when turning, thus putting the toe out on turns out.
  1. HSV GTS Steering wheel vs SSV Steering wheel / Re trim ?
    By geo41e in forum VE Holden Commodore (2006 - ?)
    Last Post: 07-12-2010, 04:53 PM
  2. [ACT] MOMO steering wheel & no brand steering wheel
    By calais24/7 in forum Parts And Other Items For Sale
    Last Post: 23-02-2010, 05:33 PM
  3. Adjusting the angle steering wheel / steering column
    By Kabooooom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2010, 05:12 PM
  4. after market steering wheel made steering crap!
    By jet_pilot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2008, 09:07 PM
  5. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
