Heyy
my VR shacks when i accelerate im think its the centre bearing
or what ever its called like near the uni joints what do yous think?
If when you take a lead off the coil and no change to the engine then this is the dead coil/lead/plug. If the engine gets worse then that coil is OK.
See if you can swap it with a know good unit (DFI & coils).
But I'd say from what you have said it will probably be a coil gone bung.
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
no worries here you go try here>>>> replacing centre bearing best of luck
Yeh thanks heaps guys yeh sounds like my centre bearing happens in low gear nd that gets real anoying
what u mean cheap for me.. why?
