Hey guys
wondering what the bumping/ shaking if right in the middle of my VR.
Im thinking centre bearing ( ithink thats what its called) what do use think?
I am sure you did not need to create two threads to get your answer.
If when you take a lead off the coil and no change to the engine then this is the dead coil/lead/plug. If the engine gets worse then that coil is OK.
See if you can swap it with a know good unit (DFI & coils).
But I'd say from what you have said it will probably be a coil gone bung. or try your leads
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
Thanks just bad how UNO all bout commys? All so mate above just it didn't send thru first time cause comp up that ok wit u?
What? BUMPY SHAKING in the middle of vr Still no need to be posting in both of them
Maybe a moderator should lock one of these threads to resolve the confusion.
