Results 1 to 14 of 14
Thread: Recommend a good-non droning catback setup for a VR V6
    93' Pov-Pac
    Jul 2010
    Default Recommend a good-non droning catback setup for a VR V6
    Yes another exhaust thread...
    My current setup on my VR V6 is: Advance headers, stock cat, 2.5" redback catback (to suit live axle) with no rear resonator (not sure if its mandrel bent but i would assume so).
    My issue with my current setup is that it drones lightly at 100kmh on the freeway (at just under 2000 rpm in 4th). It also drones around 2000-3000 rpm, particular if the car is carrying extra load. I want to get rid of that drone (the typical buick 3800 mellow groan).
    I'd also like the exhaust to sound good (for a buick V6) It has a decent burble on idle, doesn't sound too good cruising, and sounds ok in the higher revs. Ideally it'd sound good on idle and while cruising around town/on the highway as the car spends most of its time below 3000 rpm. A good note above 3000 would also be great for when i put my foot down. Basically deep, harsh and crisp.
    1. Will putting a long hotdog at the rear of my current catback get rid of the drone and sound half decent?
    2. What tends to be a good sounding setup for a Buick 3800 with headers?
    3. I've heard people say this setup is decent, and sounds significantly different to a redback. True or not? 2.5" CAT BACK SPORTS EXHAUST VN VP VR VS COMMODORE (eBay item 360317623917 end time 06-Feb-11 21:56:55 AEDST) : Cars, Bikes, Boats
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Good luck with getting it to sound good everywhere in the rev range.
    1. Fitting a hotdog will reduce the drone, but it won't eliminate it. Nothing will apart from fitting a standard system.
    2. All 2 1/2" singles with the same configuration will sound similar, you could try changing the centre muffler to a chambered glass packed muffler and fit the hotdog.
    3. Supercat systems tend to be louder than Redback. Some people like the sound of Lukey systems, but exhaust note is all subjective.
    Visit my Facebook page
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Twin systems tend to drone less at cruising speeds. Mines really strange.
    1000-1400rpm, loud burble/rumble - eg going 50km/h in drive (tcc on), moving to 3rd shifts down a gear increases rpm and makes it quiet.
    1500-2200rpm, completely silent - most cruising speeds.
    2300-3200rpm, really bloody loud
    4000+rpm, reasonable level
    that's with pacemaker headers, twin 2 1/4" system twin cats, twin mufflers no resi's
    93' Pov-Pac
    Jul 2010
    Quote Originally Posted by Not_An_Abba_Fan View Post
    I'd be happy enough if the drone was reduced significantly.
    The car may see a manual conversion in future and will get headers to suit manual, which don't drone at all apparently.
    Would a supercat system drone worse than a redback as its louder, and would it be EPA friendly?
    Quote Originally Posted by nathanVS View Post
    Yeah smaller pipes will drone a bit less, but i havent seen any off the shelf twin systems for a VN-VR
    And i think the Ecotecs drone a bit less than the Buick 3800. They definitely do sound better though.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive got a single cheapo sports system with no rear muffler on my V6 ecotec,and it used to get a drone up at certain revs,but after I fitted pacemaker extractors,I found that it pretty much stopped the drone enough so its not as annoying any more.Ive also found that while mucking around with different memcal tunes,that I get a slightly different exhaust note when I run a lot of ignition advance.It makes it sound different,somewhat deeper,it sounds better.
    VS ute
    Jan 2010
    townsville
    I could be very wrong here,
    Maybe a standard V8 cat back exhaust may fit?!? I wouldn't know if it lines up with the V6 system. Might be worth looking into as it would be larger piping but not over the top and id imagine you could find it cheap.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Standard V8 and V6 systems are the same......
    (Factory systems had a different rear muffler but all aftermarket ones are the same)
    vn executive s2 v6
    Jun 2008
    hi
    i have an ecotec with 2.5 cat bac exhaust with a flowmaster single in twin out rear muffler, standard centre muffler and cat.
    it has the most shocking drone at 95-100 kph
    im considering moving the flowmaster muffler to the centre and running twin 2 and qurter pipes over the diff and fitting to resonaters (cobies) at the rear.
    do you reckon this will decreas the drone or just make it worse???
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    3. Some people like the sound of Lukey systems, but exhaust note is all subjective.
    +1 i had a lukey catback system on my VR just 2.5 sports center with straight tailpipe, and it never droned, had a nice bark up top and had that nice burble on idle.
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    put paccies on and it will sound way better
    Quote Originally Posted by jonboy View Post
    hi
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    VR '93 Calais
    Sep 2011
    Forster, NSW
    I have a VR Calais and I've had my system in for about 6 months now. I got pacemaker headers, twin hi-flow cats to a 2&1/2" straight through with rear resonator and it sounds pretty decent. gargles on idle, and in drive from 1000 to about 3000rpm. crackles like a bitch on the decel aswell. doesn't drone on the highway at all either. then again I did spend $1600 on the system so it bloody well should sound half decent haha
    VR Calais, T5 Converted
    Selling auto gearbox and associated parts cheap, inbox for details
    L67 Calais's Avatar
    L67 Calais is online now Donates His Member
    VS CALAIS Series II Supercharged L67
    Jul 2008
    Andrews Farm, SA
    Welcome, & Nice thread dig dude.
    MY WEAPON: http://forums.justcommodores.com.au/...ng-10-psi.html
    NEED 3.9 or 3.7 DIFF GEARS, PM ME IF YOU KNOW OF ANY
    Quote Originally Posted by wraith View Post
    Mace spend time and money developing a good product and making sure there's gains to be had. Backyard mechanic wants to make wood blocks. Discuss.
    VS Berlina/ KJ Verada
    Sep 2006
    Quote Originally Posted by klampy View Post
    Agreed. I have the same on mine and I have always been happy with how it sounds.
    Damn, fell for it. I didn't see the date! Oh well...
    95 VS Berlina
    http://forums.justcommodores.com.au/...ml#post1891856
    I need some statesman/ calais woodgrain for drivers side panel!!
  1. Recommend me some good subs.
    By axemurderer101 in forum Car Audio
    Last Post: 22-03-2011, 08:28 PM
  2. can anyone recommend a good camber kit
    By lodgie in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-05-2010, 01:23 PM
  3. Recommend a good non-efi V8 tuner/workshop
    By TEMPA1 in forum V8 Development and Modification
    Last Post: 27-02-2007, 10:35 PM
  4. Recommend good QLD -> VIC car transport?
    By holdenrules in forum The Pub
    Last Post: 23-12-2005, 11:29 PM
  5. Recommend a setup for VT
    By AirStrike in forum Car Audio
    Last Post: 03-11-2005, 07:02 AM
