Results 1 to 6 of 6
Thread: Removing VS Headlight Switch *Help*
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Default Removing VS Headlight Switch *Help*
    Hey Guys,
    Just wondering how to remove the headlight switch from the dash surround facia. The facia its-self is out of the car, the one i'm putting in actually has no switch in it - but I have 2 facias with the switches in so I just need to move the switch from one facia to another so I can put it in the car
    Any advice much appreciated!
    vs commodore
    Oct 2009
    Tamworth NSW
    To remove the headlight switch,the VS gregorys manual says:
    A)Carefully pull the outer knob, and then the inner rheostat ring from the switch.
    B)Using suitable long nose pliers,turn the switch retaining bezel anti clockwise and withdraw the switch from the instrument cluster surround panel..
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    If your acually looking to remove and replace the switch from the dash surround pannel, all you have to do is Prize the switch part off. To do that get a little flat bladed screwdriver and put it into the side where the dimmer switch is and slowly work it off. You should be able to work out the rest from there.
    Quote Originally Posted by nathanVS View Post
    Hey Guys,
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Sep 2005
    no worries at all,cheeers
    Cheers guys got it off
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    took me a bit to figure it out the first time I took mine out to lol
  1. Post on how to wire up headlight off switch to interior light door switch
    By Bookanun in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2010, 12:19 PM
  2. Removing Headlight switch from dash
    By Miss-E in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-10-2006, 12:25 PM
  3. Headlight switch removing/replacing
    By vt_hsv in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-06-2006, 07:26 PM
  4. Removing Dash Parker and Headlight Switch.. ?
    By Grommitt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-04-2006, 01:31 AM
  5. Removing aircon controls, mode switch, light switch
    By wrx884 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-03-2006, 10:53 AM
