Results 1 to 24 of 24
Thread: Performance Shift Module VS stage 2 shift kit
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Default Performance Shift Module VS stage 2 shift kit
    whats the better of the two for take off ? my top end is fine...having an auto on a v8 is little slow of the mark for me,,so what of the 2 items above would be (better) cheeers
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    I can't see either having an effect on take off? Your 1-2 shift would be improved no doubt there but as for your take off I think you'd be better off looking at a high stall converter.
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    Sep 2005
    WHAT WOULD A high stall converter cost up against a stage 2?.
    Quote Originally Posted by D3V14NT View Post
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Stall/Torque converters start at about $500 and go up from there. And that's just to supply the parts. And then your car would be less powerful below the stall point.
    I would go diff gears first. Stallie for when you get a cam.
    Ronald Reagan (1986)
    Sep 2005
    diff gears? i just want more launch on take off from the auto without doing the gears if i can? the 185i hsv plenty of guts and go(just bugger all on take off or not how i would like it lol)>>>
    Quote Originally Posted by acarmody View Post
    VX Berlina
    Apr 2007
    Well a higher RPM stallie will allow you to hold the brakes down longer in the RPM range and allow you to 'launch' higher in your power band, but you will lose some milage in normal driving since you will need more gas to tack-off normally. Also 'stalling' it up so high will generate a LOT of heat and trannies absolutely hate that, so a big trannie cooler would definitely be in order.
    But seriously what tyres are you running? If you can't break traction with stock tyres doing a 2000rpm stallie dump with the stock stallie than there's something wrong with your car. So unless you have some really grippy tyres, I wouldn't worry about a bigger stallie.
    vs commodore
    Oct 2009
    Tamworth NSW
    As mentioned,lower diff gears will help get it off the line way quicker the the standard 3.08:1 ratio.Its not too expensive either.Lots of people seem to go for 3.5 :1 or or lower,a popular size is 3.75:1,it keeps some drivability on the highway.The lower the diff gears,the higher the engine will rev at 100kmh.You dont want to go too low and have it reving at 4000 rpm at 100kph.
    Sep 2005
    brand new mate 3weeks old Bridgestones.i dont take that v8 often so i say thay would be lucky to have done 100km the old tyres i could smoke up/spin the weels easy with 60% tread the bridgies stick like glue on take off
    all the running gear is 100%
    VX Berlina
    Apr 2007
    I still think diff gears would be the way to go.
    But if you really want to go stallie, than think about a cam too. These two items preferably should match up, you buy a stallie to match your cam generally. And seriously, the 5.0L loves cams.
    Rusty's Avatar
    Rusty is offline ٩(-̮̮̃•̃)۶
    304 Ute, WRX Impreza
    Mar 2010
    Queensland
    I got the VR SS 5L basically stock and a VR 5L ute with cam, mild stall and a shift kit and the difference is amazing!
    I realise the ute is lighter but it completely eats my stock SS. Acceleration heaps better with much much firmer shifts! Heaps more fun!
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Quote Originally Posted by CustomCruising View Post
    A ute is heavier.
    Exec. Sedan Exec. Wagon Ute Ute S V6 Ute S V8
    Gross vehicle mass (kg): 2051 2122 2192
    Kerb mass (est., kg): 1362 1398 1354 1356 1443
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Rusty's Avatar
    Mar 2010
    Queensland
    Quote Originally Posted by Vee-ard View Post
    A ute is heavier.
    True? I thought ute was light for some reason! Shows how much research i had done!
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    Yeah it got me the first time I saw it as well. I think the general dynamics of the ute make it feel lighter.
    The hall of fame:
    ಠ_ಠ
    Sep 2005
    what did all that cost you at the end off the day?if i may ask
  15. #15
    Rusty's Avatar
    Mar 2010
    Queensland
    Am i reading that wrong or is the UTE curb mass 8kg lighter than the sedan?
    Ute 1354
    Sedan 1362
    The GVM of the ute is higher at 2051 but that is at its capacity. I still may be looking at it wrong
  16. #16
    Sep 2005
    ya learn somthing new every day(i thought it was lighter)thanks
  17. #17
    Rusty's Avatar
    Mar 2010
    Queensland
    Quote Originally Posted by justbad4you View Post
    Unsure sorry mate, it all came with the Ute. Am catching up with the previous owner tomorrow and i will try and find out for you
  18. #18
    Sep 2005
    thanks a heap have a good week end
  19. #19
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    You're looking at it fine, but we're talking about the v8 ute here, not the v6 ute
    so 1443 kg..
    The hall of fame:
    ಠ_ಠ
  20. #20
    Sep 2005
    sorry if i didnt mention v8 ute,,,thanks vee-ard
    so 1443 kg..
  21. #21
    Rusty's Avatar
    Mar 2010
    Queensland
    so 1443 kg..
    Knew i was missing something! Gotta stop replying after midnight!
    Cheers for clearing that up mate
  22. #22
    Sep 2005
    no worrries custom
    cheeeeers
  23. #23
    Rusty's Avatar
    Mar 2010
    Queensland
    A ute is heavier.
    I am still not completely convinced the vr v8 ute is heavier than the vr SS sedan (not trying to start argument, just interested). The above figures are only for the 6cylinder sedan, not the SS V8.
    Cannot seem to find the GVM or kerb weight for the vr SS at the moment but i will keep looking.
  24. #24
    Sep 2005
    not sure what or how it all works.....maloo vs111 abs,lsd live axle,elec windows,hevier loooking fron bar? hsv towbar and all the other extras as ss spac have( a stock as rock ? will be way less with out all the options ive stated,,i wonder on what thay base the weight?
  1. gearbox and ecu questions also Performance Shift Module anyone used one before
    By VR_Acclaim in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2010, 07:15 PM
  2. Stage 2 or Stage 3 shift kit?.....can someone just quickly explain
    By S2_VR_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2009, 03:25 AM
  3. shift kit and shift module?
    By VRV6BT1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 09:18 PM
  4. Stage 2 shift kit
    By Col74 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-05-2007, 08:28 PM
  5. vn stage 3 shift kit
    By VN-88 in forum Parts And Other Items For Sale
    Last Post: 07-05-2006, 10:24 PM
