Results 1 to 13 of 13
Thread: VR Oil Consumption
    1994 VR V6
    Dec 2009
    Newcastle
    Unhappy VR Oil Consumption
    G'day.
    I'm having what I perceive as a slight problem with my V6 VR(Either that or I am paranoid) with high oil consumption. On a recent trip from Newcastle to Melbourne (1134km) my engine managed to consume a bit of oil (I refilled it her place, put in about 1 litre?)
    On the return journey I had to refill with another litre or so of oil. Just recently, with trips to and from Western Sydney (400km approx per round trip, approx 2400km total) my motor seems to be chewing oil (I've had to refill it twice so far. One with 2L and the other with probably 500ml).
    The motor has no leaks, and there is no oil in the radiator since I only just flushed that out. I've been using HPR 30 as my oil of choice and I thought I may have chose the wrong viscosity.
    On perhaps a related note, since the high oil consumption sometimes went a few KM without oil retreatment, my motor now sometimes has a slight ticking sound when I first start it. Could I have damaged the lifters or something during this?
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    The ticking on start up is no oil up the top of the engine, so to speak. Stops once the oil pressure is up.
    Does it blow smoke?
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    1994 VR V6
    Dec 2009
    Newcastle
    Quote Originally Posted by Hangman View Post
    Does it blow smoke?
    Only under heavy acceleration when the "Economy" button is pressed in from what I've been told.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    How many k's on the clock? I had a VH that used a bit of oil too, but it had a heap of k's on it.
    An old motor will use some oil, even my 130,000 k VY uses around 50-100 ml every 6-7,000. Maybe switch to a slightly heavier oil?
    Hangman's Avatar
    Jan 2010
    Yeah going by the k's posted above, plus vehicle age, I'd imagine it's got a lot of k's on it.
    You could try a heavier weight oil. That will stay thicker when hot, but it depends where the oil is going. My guess is it's just a tired motor and it's burning it. ie: Oil is getting into the combustion chamber past the rings.
    1994 VR V6
    Dec 2009
    Newcastle
    Quote Originally Posted by VYMAD View Post
    According to the Odo, it's done 167xxx. But that's broken so I have no real way of telling.
    Hangman's Avatar
    Jan 2010
    To add to that, a heavier weight oil will reduce loss if that's the case.
    tommySV6Ute Guest
    Comes with old age, a little leaky here and there, odd gasses getting released from the arse end. Was it 167,000K's 5 years ago?
    Try a thicker oil like that Shell stuff 'for older engines' or something similar http://www.supercheapauto.com.au/onl...215337#details
    5.0L VS EXECUTIVE
    Mar 2010
    How long have you been running penrite oil?? if you have only just changed recently that is normal, penrite oil will unseal an engine that has not had it run in it before, and after approx 1 to 2 months it will seal up again.
    THIS HAS HAPPENED WITH EVERY CAR I HAVE BOUGHT AND CHANGED TO PENRITE OILS, they use oil for the first 1to2 months then will seal up and not use a drop.
    I have a vs ecotec with 300,000 on the clock running penrite and does not use a drop between changes.and yes it is the original engine.
    96 VS ute, L36 Auto.
    Pacies, 2" catback, 18" RJR Shaddows
    No more V8'S, GT35 TO GO ON SOON
    5.0L VS EXECUTIVE
    Mar 2010
    If you need to go to a heavier oil use a penrite oil, maybe hpr50 it is good oil.
    vs commodore
    Oct 2009
    Tamworth NSW
    I use penrite HPR15,which is a semi synthetic 15W-60 oil in my VS ecotec thats got around 150,000 km on it..This oil stays a bit thicker at high temperatures,but is still thin at low temps so the oil still gets around the engine quickly at cold startup.
    1994 VR V6
    Dec 2009
    Newcastle
    Quote Originally Posted by Blakvsexec View Post
    I've only been using it actively for a month or so. I say actively because when I first put it in, I didn't use the car for a month or so.
    Just out of curiousity, how much does it cost to get a motor reconditioned these days? Can anybody recommend a spot in Newcastle area? Willing to drive to Sydney if I have to.
    -Twisted
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
    Would be good to know, My VX after 10,000kms the oil is in between the Add and Full mark. I use 10-30, Maybe i should switch to thicker stuff.
  1. gas consumption
    By scottyz999 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-02-2010, 03:40 PM
  2. VY V6 oil consumption!!!
    By oilburner681 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-08-2006, 09:35 PM
  3. SS vs SSZ -->fuel consumption
    By bern5 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-04-2006, 12:05 PM
  4. GAS consumption
    By comtim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-04-2005, 02:55 PM
  5. Bad Oil Consumption
    By zoidberg in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2003, 04:48 PM
