Results 1 to 6 of 6
Thread: Rim Legality's in QLD on 96 VS
    Zarconia's Avatar
    Zarconia is offline Outrageous Fondler
    96 VS Executive Series 2
    Aug 2010
    Rockhampton
    Default Rim Legality's in QLD on 96 VS
    Gday guys.
    Just wondering what is the largest rim size i could go on my 96 VS sedan in QLD? Ive been told by my friend that 18" is as high as it can go as he was done for having 19's on his a few years back, however its perfectly legal to have them on the same year and model ute. Id post my placard readings but it seems the "bright" previous owner has removed it.
    Im assuming it would be the same reading as a VR? As my 94 VR's placard has 205/65 R15
    Just that there are a few people here running around with 20s on their VR's =/
    1994 VR V6
    Dec 2009
    Newcastle
    The QLD Transport pamphlet states:
    "The rim diameter may be varied from the standard size but the overall diameter of the tyre must not vary by more than +15mm or -26mm."
    "Generally, to meet these limits, 60 series tyres are fitted to rims with a diameter increase of 26 mm larger than standard and 50 series tyres are fitted to rims with a diameter increase 50mm larger than standard."
    VY II S V6 Supercharged and 911 Porsche 996 3.6
    May 2009
    VIC / NSW
    This is your guide - from Transport QLD.
    You must comply with all tyre load, wheel/tyre width and tyre diameter limitations.
    (When in doubt the "base" to work from is the tyre and wheel fitted to your particular car as original equipment when new). Additionally, the absolute minimum tyre load limit for the vehicle is stated on the tyre placard.
    http://www.tmr.qld.gov.au/~/media/c7..._vehicles2.pdf
    (And yes you see quite a few illegal tyre fitments on Pre VE Commodores - usually tyres that exceed the maximum diameter limitations).
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    qld transport are pretty tight...wow makes rta in melb look good
    Quote Originally Posted by Twisted View Post
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    VY 3.8
    Nov 2010
    Maroochydore
    Quote Originally Posted by justbad4you View Post
    I find qld regs very reasonable... All of it is common sense not stupid rules that don't make sense...
    Sep 2005
    so is the rta in melb.....not as bad as QLD on some issues and prob worse on others
    Quote Originally Posted by Daggy082 View Post
    All of it is common sense not stupid rules that don't make sense) WHO IS DISAGREEING? (not me)
