Results 1 to 5 of 5
Thread: Standard ride height of a '94 VR Berlina
    V6 VR Berlina - Stock standard
    Sep 2006
    Brisbane (Southside)
    Question Standard ride height of a '94 VR Berlina
    Can anyone tell me the standard (factory) front and rear ride height, e.g. hub to guard, of a VR Berlina - with IRS if it makes a difference.
    Mine is sitting on the original springs and I'm wondering how much they have sagged and whether I should replace them when I replace the shocks/struts - they have all done well to get to 203 000 km.
    Thanks in advance.
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Quote Originally Posted by BerlinaBoy View Post
    Thanks in advance.
    Depends who's measuring, normally its from the road to the lowest point of the vehicle (anything, exhaust, bodykit). I think vr has standard clearance of 143mm
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    Sep 2006
    That would be about right for the exhaust, but since the rubber mounts would have stretched and the exhaust is a replacement I'm not sure if it means much. Exhaust certainly looks like it should be higher, including the hole forming just behind the cat where the pipe has scraped a couple of times.
    I make the sump as being about 175 mm off the ground and centre of wheel to guard lip distances (on level ground after a quick bounce) as being about:
    Front driver's 370 mm
    Front pass. 380 mm
    Rear driver's 390 mm
    Rear pass. 380 mm
    So she's a level on the passenger's side, but a bit out of whack on the driver's side and overall. Anyone know if that's enough to make a difference? Sounds a bit suss to me.
    Seems to be a few stats for lowered suspension around, so I might try to back-calculate from those.
    Sep 2006
    Update: Redbook here says the height is 1478 mm and a level on the roof to a tape says mine is 1450 mm, so yeah, she's dropped a bit (28 mm, just over an inch!) as expected.
    Seems to make it somewhere equivalent to between FE2 and Low from what I make of it, which is worth noting if you're interested in lowering your car.
    Anybody else have some measurements from theirs so I can confirm? Only takes a min. (BTW mine is a V6)
    Sep 2005
    ive got fe2 on mine so no point in me measuring that...
  1. Level Ride Suspension — Ride Height Compressor
    By Quill in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-12-2010, 09:38 AM
  2. Standard ride height
    By revman1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-01-2008, 01:21 PM
  3. Vk standard ride height
    By blakestone01 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-12-2006, 06:09 AM
  4. Standard Ride Height?
    By frenzal_tom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2006, 01:26 PM
  5. vp standard ride height
    By tweakt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-05-2005, 10:09 PM
