Results 1 to 4 of 4
Thread: VS L67 engine fuse blowing
    VE2 SS Voodoo
    Jul 2005
    Default VS L67 engine fuse blowing
    Hey guys got a bit of an issue, my car keeps blowing the Engine fuse in the eng bay - 20A one.
    Ive found that with the fuse out and on the side to give power from it has a short to ground (hook up multimeter Pos to give power side and NEG to batt Neg and i get continuity)
    it only happens with the ign on and the EFI relay in(or if i brige the 30/87 terminals in the relay socket it does it to), from the wiring diag i have from my gregorys ive disc everything on that circuit (ECU, oil pressure switch, DFI module and injectors) and i still get continuity to ground i then pulled apart the DFI connector to have a look at the wiring inside all looked ok half re-assembled the connector, re-connected all the other bits and i had no continuity to ground from the fuse?? so i put another fuse in and it started, idled ok but as soon as i stalled it up it started missing slighty then died, fired up again and the fuse blew once more.
    Has anyone had a DFI module play up or give any issues? ive swapped it now with a test one out of a VT NA V6 and its still doing it, could it be in the wiring? am i best to take it to an auto elec?
    Any help appreciated
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    If the solenoid had an internal short it would blow the fuse. It could also be a bad connection or a chafed wire shorting out somewhere. I've fried a few cables when they touched the cat
    Quote Originally Posted by nick88 View Post
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    VE2 SS Voodoo
    Jul 2005
    figured it out, found the red wire which is the one that runs from the eng fuse, had melted n was shorting out against the passenger side cylinder head, fixed that n no more fuse blowing
    Sep 2005
    fantastic........and no cost to fix(best way)
  1. Engine fuse keeps blowing
    By bkhwong in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-04-2011, 05:47 PM
  2. My fuse for the dash lights is blowing (number 1 - 15amp fuse)
    By aussie7 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2011, 06:10 PM
  3. vr engine fuse keeps blowing
    By bang_chong in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2010, 07:38 AM
  4. VS BLowing Engine Fuse
    By smakked in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2010, 09:55 PM
  5. Engine Fuse Blowing
    By Acclaim96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2009, 01:13 PM
