Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: V6 vx injectors into a vr how do i change over the regulator
    jharv58 is offline jharv58
    vr executive s1
    Nov 2010
    rockhampton
    Default V6 vx injectors into a vr how do i change over the regulator
    i changed the injectors over a while back but i didnt bother looking into the regulator should i try and swap that to and if so how can i do that. or is it just a waste of time. cant really find much on the net
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Quote Originally Posted by jharv58 View Post
    this 1 >>>> http://forums.justcommodores.com.au/...help-pic-2.jpg about $60 NEW from amcap
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    vr executive s1
    Nov 2010
    rockhampton
    Sep 2005
    post a pic if you can
    ok just look at mine and now im abit confused is that on the return line
    vr executive s1
    Nov 2010
    rockhampton
    Sep 2005
    and now im guessing that the little one on the rail isnt a regulator
    look at this pic >>?? http://forums.justcommodores.com.au/...help-pic-1.jpg
    vr executive s1
    Nov 2010
    rockhampton
    vr executive s1
    Nov 2010
    rockhampton
    i have found the one in the first pic i just want to know if its wat i should replace or the other one because i cant swap over the one on the rail because i cant take the hole thing off the vx rail
    Sep 2005
    this is the little one im talking about http://us1.webpublications.com.au/st...110767_5lo.jpg
    but wats the one in the first pic
    ITS GOING TO COST YOU BOUT $60...is the 1 on the car not doing its job? yes the 1 your talking about is in the 2nd pic i sent, if it was me? yes id replace at the time i did the injts>>thats me if you short on $$$ the old one should be fine(if its not playing up) cheeersa
    vr executive s1
    Nov 2010
    rockhampton
    Sep 2005
    [QUOTE=jharv58;1763475]not sure if its right for the vx injectors .................. flow rate is smaller (not my much 1cc from memory), but better atomisation. if you drop in the VX injectors drop in the VX fuel pressure regulator too, that will ensure the correct fuel pressure is maintained.
    this answers your quetion......change it....oh and good luck....cheeers
    vr executive s1
    Nov 2010
    rockhampton
    ok correct me if im wrong bt the one in the first picture u put up is that the actual regulator
    vr executive s1
    Nov 2010
    rockhampton
    cheers i will do that u wouldnt know the part number of the top of ur head would u if not il just look it up
    Sep 2005
    lol want me to pop over and put it in 4u( im kiddding) no not of hand ring holden or repco and thay will give it to you...best of luck
  15. #15
    vr executive s1
    Nov 2010
    rockhampton
    nar iv got no problem doing it i was just given a bum steer on the hole thing and was thinking of the wrong thing haha dont u love that and cheers
  16. #16
    Sep 2005
    get in there with the grease i say lol ...go for it...i hope it all goes smoooooothly 4ya cheeeers
  17. #17
    vr executive s1
    Nov 2010
    rockhampton
  18. #18
    Sep 2005
    ANYTIME have a good weekend and a better weeks start on monday
    yeah me to haha thanx for the advice
  19. #19
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    to my knowledge you only have to change the regulator if you put the super6 injectors in (white) otherwise the pressure is much the same. should be at approximately 3bar.
    the super6 has more fuel pressure i think its about 3.5bar.
    edit: the one behind the TB is a damper. it just helps to smooth out the supply pressure for moments when u slam the throttle shut to stop the lines shuddering.
  20. #20
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    The eco Tec and Buick regulators are different and the lines are pressed onto the vx one correct me if I'm wrong, but they aren't interchangeable,
  21. #21
    vr executive s1
    Nov 2010
    rockhampton
    so theres no point in changing it. or if theres a point how would i change it and what to because i cant get the one off a vx fuel rail
  22. #22
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
  23. #23
    Vr acclaim
    Jun 2010
    It's the vacc ur motor creates that cause it open allow more fuel back into the tank, not to the injectors, and u would still only be gettin the stock fuel pulse with out a tune, all ur doing is allowing it to run abit richer, also just sompeople are aware the best injectors ive found on a stock v6 and edible 4cyl tr magna injectors the cream ones, as for fitting the regulator all the hoses are bigger and the fitting
  24. #24
    Sep 2005
    Quote Originally Posted by VR_Acclaim View Post
    so do you think he should get a new 1 ? or save hes $$$ (or is it a case of if it aint broke dont fix it ) cheers
  25. #25
    Vr acclaim
    Jun 2010
    If it isn't broken leave it, a new one won't allow more pressure as there not on the in line there on the return, and the injector will only pulse so much, bein a vr the map sensor ran, so u would need a bigger map sensor to accomindate more air/ fuel ratio, which won't be effective unless ur running high comp, leave the fuel reg and do the plugs perhaps? Don't bother buying expensive ones as it's the same with spark ur stock coils will only spark so hard and it won't be enough to need 30 plugs, did u change ur filter? If not do so as urbinjectors may not be workin to full capacity with a clogged filter anyway
  1. [NSW] FS: Turbosmart regulator and blow off, 60LB Injectors, Ecotec REVERSE top plenum
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 28-10-2010, 07:40 PM
  2. [QLD] Injectors and fuel pressure regulator
    By KingCoMMoDore in forum Parts And Other Items For Sale
    Last Post: 01-09-2010, 04:22 AM
  3. how to change a rear window regulator?
    By kizza50 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2010, 05:57 PM
  4. Fuel Regulator Change over help
    By Full Spectrum in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-04-2006, 03:22 AM
  5. FS:VN Injectors,Fat Rail,Regulator
    By Gazza2005au in forum Parts And Other Items For Sale
    Last Post: 15-07-2005, 11:33 AM
