Results 1 to 4 of 4
Thread: VS Remote Central Locking Problem
    VS Executive Wagon 3.8L
    Oct 2010
    Queensland
    Default VS Remote Central Locking Problem
    Hi Guys.
    '97 VS Wagon
    When driving, intermittently all indicators flash as if the remote locking button has been pressed. Obviously a problem when actually driving the car.
    I have tried:
    Replace Flasher Relay
    Replace Ignition Key - Now same problem with 2 different keys.
    Temporary workaround. I have removed the fuse from Hazard Warning Lights. I can still hear the actuator clicking while driving, but the lights don't flash any more. That fixed the immediate safety issue.
    Now all remote locking and indicator lights work correctly, except no indicators flashing when I use the remote locking. Plus of course no hazard warning lights.
    I suspect maybe a faulty remote sensor sending signals to the actuator or the actuator itself. I'm not familiar with the locking system at all, I don't even know where the sensors are.
    Any help would be appreciated
    Steve
    VX SS
    Jun 2005
    Best to check that the wiring is securely plugged into the door actuator and that the door loom wiring is not damaged, causing a short, especially where it runs through the door loom.
    Do all doors lock and unlock ok?
    Oct 2010
    Queensland
    Quote Originally Posted by tezza View Post
    So the sensors are located in the doors ?
    Pardon the ignorance, not familiar with the remote locking system at all.
    Yes all remote locking and unlocking works correctly.
    Just no flashing indicators due to Hazard Warning fuse removed
    Indicators work correctly when turning
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Hazard Warning fuse removed( put it back in and see how you go)
    Quote Originally Posted by tannum99 View Post
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  1. Ignition/Remote Central Locking Problem
    By Crossy_014 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2010, 03:17 PM
  2. Central Locking Remote Key
    By Hardstylin in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-08-2008, 08:59 PM
  3. VN S1 - Remote Central Locking - How?!?!
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2007, 04:45 PM
  4. VR Remote Central Locking
    By 5600RPM in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2006, 05:29 PM
