I'm just wondering if I could fit vs statesman clear indicators and foglights into my vr's front bar it looks like I need to cut some of it away but I know it's gotta be harder then that. Also if I were to wire foglights up where on the dash does the factory switch go?
the bar itself is the same so yes it will fit. however you are correct in that you have to cut out the little grille bit next to the indicators. the bracket should already be there ready for you behind the bar.
Sweet so I'm guessing the switch goes on the right of the steering wheel where the blank switch is?
Ok I've looked around but I can't find any vs foglights . so will vn-vp foglights fit or are there any aftermarket ones I can use? Any help would be appreciated
