I'm assuming the red rubber bits on the rear axle are the bump stops. so my ute is sitting on them at the moment, does that mean that it has been lowered, coz the previous owner said he hadnt modified it in any way.
Could they be new ones? coz the springs are also red and dont look worn and dirty the rest of the underside?
Need a picture. Are you sure you're looking at the bump stops and not nolothane bushes or ProBag inserts?
Originally Posted by Reaper:
Originally Posted by Jecs:
springs are pedders may be you have a set of pedders rear bump stops as well that would explain them being reddosnt mean its been lowered (the guy you got it off may have sent it to pedders at 1 point) it could be lowered( can you get the part no off the little tag that norm sits on the spring? if you get a part no from the springs(look it up on google AND THAT SHOULD LET YOU KNOW IF ITS BEEN LOWERED ONTO PEDDERS SPRINGS) cheeers
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
Sweet thanks man ill have a look tomorrow and find out, also if there is no tags is there any way to tell if its lower?
yeah there like a 4wd standard am its almost tucking the 17's unloaded so im pretty sure it is lowered, though it is and s-pack, do they have lower springs as standard?
Stupid question but how do i post pics >.<
Red thing on axle
[IMG][/IMG]
Rear spring
[IMG][/IMG]
Rear wheel
[IMG][/IMG]
Front wheel
[IMG]
Front spring
[/IMG]
Thats all of em
Its not sitting on bump stops.
They're pedders springs, and the other bit looks like a poly urethane control arm bush.
Ah k, thanks for clearing it up, also does it look lower then normal?
It looks slightly lower.
There 17inch wheels man
