Results 1 to 15 of 15
Thread: Code 64 - LH Oxygen Sensor Lean (O2)
    VE Calais
    Dec 2010
    Default Code 64 - LH Oxygen Sensor Lean (O2)
    On my VS, Ive been having issues with it running rough and stalling.
    On checking the codes I originally got a Code 47 (CAS)
    I replaced the CAS (which was a bitch to do unfortunately) and to my amazement the orange light came on again as soon as I drove the car again.
    The car is still running rough but touch wood, even in the heat it hasnt stalled although ive been concerned it will.
    Its almost like at idle it needs to be 100-200 RPMs higher and sometimes on take off theres lag with any accelaration.
    I re-checked the error codes and im now getting Code 64, O2 sensor lean.
    The other thing I should mention is my fuel economy is shitful, around 18litres/100km (city driving)
    I know the sensors can become faulty but with the way the engine is running its obviously an issue.
    I checked for vacuum hoses etc and all seems intact.
    Ive always had a crack in my manifold so thats not the problem and when it gets hot it expands so theres no leakage of gases there.
    Any suggestions?
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Seems pretty straightforward...
    Replace the oxygen sensor? its obviously telling the ECU its running lean so the ECU gives it more fuel, which is why you're getting 18L/100Kms..
    My guess anyway.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VE Calais
    Dec 2010
    I wondered about that, This may sound silly, how do I disable it temporarily so as to check if it fixes the issues.
    ie without cutting the pink wire.
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by zac_sa View Post
    Cutting the pink wire wont disable the 02 sensor.It will just stuff up the 02 sensors heater,which will probably make it even worse than it is now.As said above,the 02 sensor needs to be replaced.Too easy mate.Id do both at the same time so their readings are similar.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Cutting the pink wire is actually Holdens fix for the RH sensor giving incorrect feedback to the PCM.
    Running rough and lean could possibly be a vacuum leak.
    Visit my Facebook page
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    I would replace both O2 sensors and rewire the earths.
    Mine had a really odd graph for the LH sensor so I replaced both. Still had a crappy graph, so i rewired the earths and the graph is OK now.
    Still had a slow/poor idle (fuel consumption was OK) so I cleaned the mounts for the DFI (poor earth) and all is good.
    Runs smooth.
    Well, as smooth as VS can get anyway!
    vs commodore
    Oct 2009
    Tamworth NSW
    Ive also found when doing memcal tunes, that if a VS was released with the BSTK memcal version,and you try to run one of the newer versions of the VS memcal,Like BWPJ or BWXP ,it will give bad 02 sensor readings and can also set error codes 76 and 78.Ive even tested it with the modified 02 sensor earths,and its made no difference.I wonder how many people have fitted a later memcal version and have had trouble like Ive described.At first I thought its just a problem with my car,but then Ive talked to a couple of other people who have ran into the same problem with their VS's too..The BSTK memcal version was replaced by holden for the BTXP version because of pinging and cold hesitation problems.Ive asked a few people in the know about it,and no one can say why this happens.So for the time being ,Im stuck using the older version of the VS memcal,Id like to be running an updated version as they run better,but cant because of this problem.Anyway,if you have a VSV6,its worth checking what version of the memcal is used if you are swapping over memcals like when buying a tune.Find out what version was used as the base for the tune.The version is written on the memcal itself under the blue cover,and also on the ECU sticker.Its also worth checking this out if you have bad 02 sensor readings,and cant find out whats causing it.
    VE Calais
    Dec 2010
    Ive just changed over my o2 sensors and by that I mean i swapped left over to right and vice versa. The left hand one (the one indicating the error) was black in colour and the other was white.
    I went for a test drive for a few k's and the engine light didnt come on. The fuel economy changed from 18L/100km to 15L. I checked the error codes after the test drive. (they were reset before test drive) and im not getting any new error codes.
    I'll have to wait till I drive it longer for an error code to log. Hopefully it now is the right hand side indicating as lean then I'll know its definitely the sensor and I'll replace them.
    vx s pack II
    Jan 2010
    aLKIDA
    It is easy to test the Oxygen sensor.
    When the car is started(cold) it operated in open loop mode supplying more fuel. until the oxygen sensor heats up then it will operate in closed loop mode.
    The oxygen sensor need to be at least 300 degrees to operate. They have a internal heater to get them up and running.
    Any way the way to test the sensor is to get a multimeter and put it in VOLTS (milli volts) mode dont put it in OHMs mode because you can damage parts.
    The voltage should be reading low and high continually changing.
    Rich higher voltage lean lower voltage.
    I think it ranges from as high as 800mv-and as low as 200mv. Have not done one for ages
    VE Calais
    Dec 2010
    Ok, I finally feel im making progress. After swapping the O2 sensors over, Ive now got new error codes.
    Code 44 - RH Oxygen Sensor Lean (O2)
    Code 76 - Air/Fuel ratio variation between left and right banks
    So ive just ordered 2 x O2 sensors
    2x NEW Holden VS VT VX VY VZ VE LS1/2/3 Oxygen Sensor (eBay item 150528589328 end time 03-Mar-11 22:31:29 AEDST) : Cars, Bikes, Boats
    Once I put them in, it will hopefully be the end of my engine issues. Including the weird idle, running rough etc.
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    Oh man, dont mean to burst your bubble but I've had problems with cheap O2 sensors before. First the cable wasnt even long enough to reach from the socket in the extractor to the pigtail connector in the loom, then it just threw error codes straight away, and this was for a Borg Warner "OEM" replacement sensor, It was the biggest piece of shit ever. You should have just ordered 2 Genuine AC/Delco sensors.
    "Signal output well above OEM standard"????? Um... Im pretty sure the signal needs to be as OEM as specified otherwise it throws the wrong reading to the ECU? It reads the amount of O2 in the exhaust then sends a voltage reading to the ECU, why would you want that voltage reading to be higher than what its supposed to be?
    The hall of fame:
    ಠ_ಠ
    VE Calais
    Dec 2010
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    Yeah hopefully. If its crap just send em back. But they might be decent man you never know.
    The hall of fame:
    ಠ_ಠ
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Holden charge about $50-$60 ea IIRC. (4 wire)
    Plug and play.
  15. #15
    VE Calais
    Dec 2010
    Ok, for anyone interested. I changed over the Oxygen sensors yesterday (both).
    So far so good as far as engine running goes. I havent notice any weird idles like it used to occasionally and also acceleration is normal.
    However it may be too early to tell as alot of the issues were also intermittent.
    Ive not had the engine warning light come on and thats a huge plus as it would almost definitely have showed up by now.
    As for fuel economy no real improvement.
    When I swapped the old sensors from left - right and vice versa my fuel economy was around 14-16L per 100km.
    Now its around 13-16L, a far cry from the 11 is should be but its always been anywhere from 11-13 for city driving anyway.
    So not sure why the economy is down.
    Anyway Im hoping to get a VE Calais (black colour) as soon as one becomes available.
    Rare as hens teeth, then the VS will be up for sale. Besides the engine issues ive been having, its a very nice car and will be sad to part with.
  1. 304 Code 13 - RH Oxygen Sensor (O2)
    By betts in forum V8 Development and Modification
    Last Post: 14-11-2009, 08:16 PM
  2. Code 44 - Oxygen Sensor Lean (O2)??
    By rooooboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-10-2009, 02:43 AM
  3. code for oxygen sensor.what should i do?
    By dylanfh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-04-2009, 07:53 PM
  4. code 44 oxygen sensor lean
    By Vt-Brrrlina in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2008, 03:25 PM
  5. code 13 oxygen sensor
    By 8vl in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-08-2008, 01:25 PM
Tags for this Thread
