Results 1 to 18 of 18
Thread: VS on its last legs, some advice?
    VS Acclaim
    Jan 2011
    Default VS on its last legs, some advice?
    Hi, new here
    We have a VS Acclaim sedan and it would seem it's very close to dying completely. In the last few weeks its just going downhill.
    It has a
    New water pump
    New thermostat, was the wrong one, currently has none.
    New radiator
    Main issues-
    The previous rumble (that was mainly an exhaust that needs replacing) is now a full car shudder when its turned on.
    The temp gauge is very erratic, but doesn't say its ever on the red even though the cars behaviour says otherwise. Connected to the fact it has no thermostat?
    The heater tap leaks and leaves the car steaming and smelling.
    Loud sloshing sound (although I read online that could just be water going through the heater core and some cars do it, some don't. Is that right?)
    And the loveliest thing of all, when it warms up and you've driven a few kms, the motor starts knocking.
    Tried replacing the leads and spark plugs but we didn't have the right tool for the spark plugs. With the leads, well, changed them over and it quietened down and ran better, however by the end of the day it sounded way worse than before so put the old ones back in a day later. We have assumed they were the wrong ones.
    So, short of taking it to a mechanic (which is obviously the most logical option), any ideas?
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    vs commodore
    Oct 2009
    Tamworth NSW
    Id start by doing an error code check.Heres a link that shows you how to do this quick and easy test.If any codes show up,post up on here what they are.
    ---Checking error codes VR/VS (Revised)---
    Id also flush out the cooling system with a hose,then get a new thermostat and heater tap to get the cooling system back to how it should be.Id even throw a new radiator cap on there as well.Make sure the radiator has got the proper coolant in it and not just straight water.Then I'd do an oil and filter change,use a 20W-50 oil.Also fit new spark plugs,(double check them to make sure they are the right plugs,for NGK brand,they should be NGK BPR 6EFS 15,or for AC Delco brand plugs-they should be R42 LTS6),the sparkplug gap should be set to 1.5 mm.Also you can buy a sparkplug spanner cheap at most auto places.And as soop said above,replacing the 3 ignition coils is worth doing too if the new plugs and leads dont help...These coils seem to loose their "performance" with age,they end up breaking down completely and not sparking properly when the engine is under load,which can cause misfiring or even backfiring etc,and generally just bad running.
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    (heater taps are cheap like $15 - $30)
    Loud sloshing sound although I read online that could just be water going through the heater core and some cars do it, some don't. Is that right?
    (that might just be air try bleeding the air from the cooling system)
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    IF the car gets steamy and smelly then your heater core has a leak. Not cheap to fix. We're talking 10 hours labour to pull the entire inside of your car apart if you do it properly. If you want to get by, just cable tie your heater tap shut (obviously after you replace it with a new one, sounds like yours is rooted) to bypass the heater core and stop the leak. Or you could even reroute the water hoses in the engine bay to miss the heater core entirely.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    if your heater core is done liking life (same in my old ute smell and leak on floor) choice for you >> 1 dash out and heaps of work? or 2 cut pipes and mate new core to pipes( ill explian later if you need and post a link) are you wanting to fix the issues yourself? h/core are from $80 TO $120 NEW i did mine in 3hrs by mating a new heater core to the old pipes with oses and clamps> theres some threads on j/c. it worked a treat for me (cars been sold)
    Quote Originally Posted by darcycammo View Post
    if you going to want it back to 100% the dash is going to have to come out ( there also a thread on the dash out as well )
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    VR v6
    Jan 2011
    perth
    Yeah as everyone said:
    fix your cooling system, and heater core
    replace leads/plugs
    for the knocking, add a few liters of 98 to jack up the fuel octane. if it fixes it you can run on 95 fuel instead
    Sep 2005
    and as cheap as poss.......blooody cars lol...
    Quote Originally Posted by shadetreemechanic View Post
    replace leads/plugs
    D22 St-r Navara
    Dec 2010
    perth
    knocking at revs unless its big ends i would say harmonic balancer. last legs generally means calling up sims is just moments away. so far you have just had general wear
    Sep 2005
    sims pay$300 for a commy
    Quote Originally Posted by Krisp View Post
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    And put a thermostat back in it.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    Sep 2005
    alternator and coils go starting point
    Quote Originally Posted by Gippy View Post
    Hi, new here
    It has a
    New water pump
    New radiator
    Main issues-
    vs commy
    Aug 2010
    australia
    Could be your oil pump is a little worn. or very, my Vs did this when i first got it. for a few reasons.
    1 previous owner was a lady. so was probably not serviced properly, when i did the first oil change you should have seen the sludge that came out :O i never seen anything like it.
    that went on for 2-3 oil changes till it was flushed out. (poor car probably never seen 2500RPM till the day i got it when i got it was auto is now a manual ROFL )
    2, my cars had around 240,000 when i got it and after a bit of i suppose you could call it testing.... i found the oils for older engines made this problem worse, normally something like 20w60
    then i tried magnatech and the knocking hasn't come back since.
    just to give bit more detail.... when my car started to knock coz of this it was like there was no oil at all getting to the heads. just tapping away like crazy. car had no power, and normally happened after i had been giving it a bit of a hard time.
    someone also told me you can try flushing it our with diesel grade oil coz it cleans our your engine, but only have it in for around 500ks. then put a good semi or fully synthetic oil in.
    Sep 2005
    yeah i 2nd that HANG
    Quote Originally Posted by Hangman View Post
  15. #15
    VS Acclaim
    Jan 2011
    Hey all, thanks for your advice.
    We've taken it to a mechanic who replaced the heater tap and then told us it had a blown head gasket and that it would cost us between $1000-1500 to fix.
    And of course at the moment we don't have that kind of money lying around, so we'll have to continue to drive it til it stops.
    My bro can get us a new motor with a 3 month warranty for $500. Unfortunately it's 400km away. So now we're just waiting til next pay and then we'll somehow get the vs down there.
    So again, thanks for all your advice
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Head gasket on a commodore isnt a hard fix, im sure you can find someone to do it for a hundred bucks and a box of beers.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
  17. #17
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    Quote Originally Posted by Andrew426 View Post
    Not a hard problem to fix but if its like quite a few others the heads are probably cracked between valve seats - & that gets expensive to fix. At least with a $500 motor he knows what its going to cost..
  18. #18
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    Re-fit the new motor is probably the cheapest way...
    then sell your motor for half that price with no head. someone will buy it to rebuild for sure
  1. Replies: 18
    Last Post: 12-10-2010, 02:28 AM
  2. Darwin mums told to close their legs
    By wickann15 in forum The Pub
    Last Post: 24-07-2010, 08:08 PM
  3. 1/2 a million k's & she's running Like a dog with 3 legs
    By Rgsyes in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2010, 03:29 PM
  4. Starter motor on last legs
    By VS304exec in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-05-2010, 04:40 PM
  5. Daddy long legs
    By BURNOUT BAZZA in forum Jokes/Humour
    Last Post: 03-06-2009, 03:58 PM
