Results 1 to 18 of 18
Thread: how to removal the material underlay stuck to the floor
    peter1 is offline peter1
    vr series 2
    May 2010
    Default how to removal the material underlay stuck to the floor
    i have remove the center console, front and rear seats as well as carpet and all under lay. i have removed all the floor bung to release all the water i had to remove some of the material glued to the floor to access the bungs. Found alot of moisture under edge of the material. Does any know how to remove the rest of this material from the floor and the rubber stuff from floor of the boot.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    The stuff under the underlay is bitumen. I think you'll just have to scrape it out.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    Id try something to soften it first, maybe some orange cleaner or.... anything that will soften tar, I cant speak from experience but once its broken down use a paint scraper.
    I had to remove some from the boot of a car years ago, tried a wire wheel and it got pretty messy.
    Best RPG ever
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Quote Originally Posted by peter1 View Post
    The best way to get the bitumen coating off is use a hot air gun and paint scraper. Heat up the coating slowly and scrap it off. It will take time
    OR Before you heat up the bitumen look around for splits & cracks in it also form under the car push out the rubber plugs which will help lift up the bitumen.
    Chip up as much as you can first before you start heating it coz i will get messy.
    If heating doesnt work
    Other way is to melt it with deisel, deisel is safer as it has a much higher flash point so it will be safe to weld around after. Just were gloves & protective clothing when you use it and wash yourself very well after if you leave it on your skin it will take your skin off.
    Also another way I have used is to get a wire wheel in a drill and it will oblitorate it off the metal, just make sure you wear safety glasses when you do it, also it works better on bitumen that hasent been heated or had a solvent on.
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    vr series 2
    May 2010
    Sep 2005
    Hi thank you for all the replies hope this helps others as well
    no worries at all................................cheeeers
    VT
    Apr 2005
    QLD
    I saw someone break it out with dry ice. throw it in (with gloves on of course) and it basically chills it, then tap it and shatter it out.
    I previously used the hot air gun and scraper method.
    Very thorough, but its a fairly slow job if its thick and its a pain in the arse.
    Try the dry ice and let us know.
    Sep 2005
    dry ice costs lol ya sisters hair dryer is free lol .......
    Quote Originally Posted by VT-565 View Post
    VP Exec
    Jun 2005
    Quote Originally Posted by justbad4you View Post
    Only until she finds out what you've used it for. Then you'll pay in all sorts of ways.
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    we just layed some stuff on our 1tonner, its like tar, bitumen and like led i think haha.
    we put it on with a heat gun.. so im guessing heat it up and pull it off?
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    Sep 2005
    good heat gun........
    Quote Originally Posted by vk.jonno View Post
    vk.jonno's Avatar
    Nov 2009
    south east
    actually it was a $30 ozito one.
    its just needed to soften it and bend it into shapes
    VT
    Apr 2005
    QLD
    Sep 2005
    a good heat gun as stated above
    You'll need more than a hair dryer to pull it up.
  15. #15
    VT
    Apr 2005
    QLD
  16. #16
    vr series 2
    May 2010
    I just used a scraper and a cold chesiel to take the top of thenm i am going to use the elcetric drill and wire brush to take bits left
  17. #17
    VT
    Apr 2005
    QLD
    Try the heat gun and the scraper, a LOT cleaner than spraying it everywhere lol
    Then just clean up with supercheap degreaser
  18. #18
    Sep 2005
    i think IT SAYS HOT AIR GUN>>>>>>>>>>>>> IN THIS POST BELOW( THATS MY 1ST POST IN REPLY as stated way above)
  1. carpet and underlay/sound deadening
    By madrx3boy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-02-2011, 01:43 AM
  2. VN SS NOS Material...
    By saladine1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-05-2010, 12:23 AM
  3. underlay underneath carpet - where to buy ?
    By macksvt in forum General
    Last Post: 04-11-2009, 05:12 PM
  4. Garage Floor Oil Removal
    By vlv8vic in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-07-2005, 01:12 PM
  5. what material for a sub box?
    By vpwgn in forum Car Audio
    Last Post: 04-02-2005, 04:05 PM
