Hey,
My friend has a VR and its running a fairly high powered cammed 355.
Basically what happened is she gave it abit of stick and after that it wont drive once its in "D" on the selector. However, When shifting manually it will change gears normally.
The gearbox has everything under the sun done to it strength wise and is only 18,000ks old. Most important things would be its shift kitted and has a 3000rpm stall.
Another thing worth mentioning is that the spedo works sometimes and sometimes doesnt. I know the sensor is on the box so maybe it could be electrical?
Any help would be appreciated.
47 made with the 185i engine $62,500 new
35 made with the 215i engine $73,500 new
check is whether the gear change linkage, from T bar to the actual transmission is loose. If it is loose at the T bar, the cutouts in the gate may prevent you from properly selecting "D"....and the same for where the linkage meets the trans. If you put it in "R" what happens....same for "P"? Go to this link and see if any of the problems match yours. http://www.s10forum.com/forum/f13/4l...utions-297698/
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
Speedo sensor is on the output shaft housing at the back of the box. The 4l60e relies on the speedo sensor for information relating to vehicle speed so it is highly possible that a faulty speedo won't allow it to change gears correctly. Try putting a known working one from a mates car (or your car even if it's auto) in there and see if that fixes your problem.
1. 1990 VN Exec V6
2. 1993 VP BT1 3.8L - Now wrecking for parts!
3. 1991 VP Berlina V8 - RIP
Looking for a good condition VN - VS V8!!!
The auto trans also uses the TPS (Throttle Position Sensor) signal to help regulate the gear shifts.It might be faulty.
