Results 1 to 23 of 23
Thread: Don't know what to do anymore, need all the help I can get!
    Vs Executive S2
    Jan 2011
    Default Don't know what to do anymore, need all the help I can get!
    My dad decided to give me his 1997 VS Commodore for my 16th birthday . It has driven less then 5,000kms in the last 2 years. He was the second owner of the car and has had it since 1999. About 5-6 years ago he decided to put gas in it. When he gave it too me it wasn't in the best condition, but my project is to fix it. I decided to change the injectors because it was idling rough on petrol. I changed the injectors 3 days ago but it didn't turn out well. When I turned the car on it seemed to have the same problem, yet when I pushed the accelerator it had no power, so it was actually worse with the new injectors. I turned the car off, then went to start it again. This time it wouldn't turn on. I put the head lights on and tried to start it, but the lights turned off when I did this, so I figured the battery would be flat. I got a new battery, yet I have the same problem. When I go to turn the car on now, random lights flash on the dash, and when I put the high beams on the speedo needle goes up to 40km/h and drops back down. My dad keeps on telling me to take it to work (because I work at Kmart Tyre and Auto) but the whole point of taking this car was so that it could be my own project and I could learn more about cars by fixing it. I have no idea why the car is playing up, so all your help would be greatly appreciated!
    Cheers.
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    if you post up the error codes you get, and more detail of what you removed and replaced to do the injectors you have more chance of getting help here. It would be quite a coincidence for the battery to suddenly give it up 3 days after you decided to change the injectors. More likely you have disturbed or forgotten to reconnect something in the process.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i would be empting the tank as the fuel would be very stale, get some fresh juice. i would say the leads would have deteriorated too
    as others have said, post up your error codes.
    VS 5LT STATESMAN
    Sep 2008
    G'day check all your earth leads it sounds like you have missed /knocked something when you put the injectors in
    Jon
    Vs Executive S2
    Jan 2011
    I'll check the error codes tomorrow morning and post them up.
    Also I've already put new fuel in, its just the part where the dash is flashing random things that is getting me confused...
    I don't know what I would have touched to cause this.
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Ate ur injectors clipped in properly and is the wirin to them done properly
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    get the codes up....post them...and ppl here will help you do it 1 by 1 ( ya didnt pay for the car so you dont have a lot to loose....once all the smalll probs are fixed youll be a happy man.....dont let it get you down as its only a car....cherres
    Quote Originally Posted by Josh.69 View Post
    Cheers.
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    +1 for checking your battery terminals, earth points and power cable to main fuse box.
    if your headlights are cutting out when you go to crank it, you've got a power related problem.
    Vs Executive S2
    Jan 2011
    Quote Originally Posted by wamboin23 View Post
    I think i've found the problem, i'll upload a picture. There is a small wire on the side of the battery terminal that has snapped off.
    Attached Thumbnails Attached Thumbnails Don't know what to do anymore, need all the help I can get!-03022011150.jpg   Don't know what to do anymore, need all the help I can get!-03022011152.jpg
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    thats the alternator sense wire. should still start with it broken, the battery just won't charge.
    everything else seem ok? including the main earth to the left of the battery?
    VR wagon, 5 ltr ski boat,
    Sep 2009
    Broome
    Check the body earth next to the battery that bolts to the inner gaurd. This has given me strange problems like you described...
    Sep 2005
    did you do a code check ?
    Cheers.
    Trayner's Avatar
    Aug 2008
  15. #15
    Sep 2005
    yes both of them i say
    Quote Originally Posted by Trayner View Post
    Dude change that terminal while you have it off lol , thats like all corroded and what not . there like $10 at super shit and etc
  16. #16
    Vs Executive S2
    Jan 2011
    Just fixed this so called alternator sensor wire. Car has turned on and is running a lot better with the new injectors, just idling a little lower then I would like. Is there a guide on tuning your car anywhere?
    Cheers.
  17. #17
    wamboin23's Avatar
    Apr 2009
    Wamboin, NSW
    idle speed is not something you can change without getting the program in the computer changed.
    give the throttle body a clean out might help a bit if its noticeably low.
  18. #18
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Cheers.
    It might do that until the battery is charged back up
  19. #19
    Vs Executive S2
    Jan 2011
    I've cleaned the plenum chamber and the throttle body so that shouldn't be the problem. Also I just bought a new battery, so that also can't be the problem.
  20. #20
    Sep 2005
    your getting there....keep going.cheeers
  21. #21
    VXII Berlina 2002
    Feb 2011
    Central Coast, NSW
    Sounds like the fuel pump... but it could be a million things!
    "A drunken man's words are a sober man's thoughts."
  22. #22
    zelby11 is offline Banned
    SCOOTER
    Jan 2011
    NOWHERE
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Idle speed is set by the ecu. You can't tune your own car as all tuning is done by the ecu. Change your TPS (Throttle Position Sensor) and maybe your MAP (Manifold Absoulte Pressure sensor) Give your Throttle body a clean as well.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
  1. Odomoter Not ticking over anymore
    By jw.pfitzner in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-09-2010, 01:14 AM
  2. telemarketers not fun anymore
    By Dayvo in forum The Pub
    Last Post: 18-12-2007, 08:37 PM
  3. simpsons not on at 6 anymore
    By Sabby in forum The Pub
    Last Post: 12-12-2006, 04:58 PM
  4. Heater not hot anymore
    By cunners3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-04-2006, 11:45 AM
