Results 1 to 17 of 17
Thread: Vs starter pissing me off.
    VS Exec
    Jan 2007
    Adelaide (South)
    Default Vs starter pissing me off.
    Having a starter problem that is really getting to me, can't for the life of me figure it out.
    Now this is a new starter motor.
    Go to start the car, it cranks over a little like normal, then a wrenching sound (like the car was about to kick over) and stops... now the starter is stuck. out with a hammer and give it some love taps, try to start, nothing, more love taps, turns over a little then wrenching sound, stuck... repeat until the bastard starts.
    this is getting just a tad annoying.
    back story... initially I had a starter that was dying for a while and I let it slide, then it degraded to the point where it wasn't disengaging when running and making a hell of a racket. this prompted me to change it.
    swapped it for a 2nd hand one, worked fine for a while then started getting stuck. after a while I thought oh well get a new starter... worked well for a while, then started getting stuck...
    So I'm tending to lean towards it not being a problem with the starter itself.. but buggered if I know what is actually wrong.
    Any ideas would be much appreciated.
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Check the teeth on the flywheel.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    VS Exec
    Jan 2007
    Adelaide (South)
    did that when I changed the rear main seal, seemed fine to me, although covered in crustied up coolant crud, which I cleaned up.
    but it was happening before and after this.
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    is there a shim between the starter and the block some have a shim some dont shim will move the teeth slightly further out of mesh
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    try an error code check?
    Quote Originally Posted by Kingo View Post
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    VS Exec
    Jan 2007
    Adelaide (South)
    nothing relating to starter in error codes. only stupid ones because i'm running gas.
    VR wagon, 5 ltr ski boat,
    Sep 2009
    Broome
    V6 or 8 If its a V8 is it the correct starter? The wrong one will cause exccess engagment.
    VS Exec
    Jan 2007
    Adelaide (South)
    its a v6.
    i'll have to pull off the flexplate cover and stick my head under there while someone starts the car so i can have a good look at what is going on.
    fun times.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the shim will be missing binding up the teeth ide say
    Sep 2005
    hope you work it all out in the end....cheeeers
    its a v6.
    fun times.
    VS Exec
    Jan 2007
    Adelaide (South)
    Quote Originally Posted by delcowizzid View Post
    I don't remember there being a shim when I took off the original starter... but then it could have been stuck to it and I didn't notice.
    and unless it was somehow stuck to the block, there definately isn't a shim there now.
    any idea how thick they are?
    в∞ѕтεכ √&
    Jul 2008
    NZ
    1/2 - 1mm just a sheet metal shim the shape of the starter with 2 holes in it
    vs commy
    Aug 2010
    australia
    i agree with delcowizzid,
    recently i did a gearbox conversion, and the starter from the doner car needed a shim, but i never got it.
    got a friend to crank it with my under it and saw it was hitting the flywheel before it got to engage.
    just as a quick test i got 2 thin washers and put em in behind the bolts. and no problems. (i made the proper shim the next day)
    but when my starter packed it in... i went to get a reco one and that was shimless so just bolted straight on.
    this is for manual i dunknow about autos they are bosh mine is a delco
    VS Exec
    Jan 2007
    Adelaide (South)
    i reckon you two might be right. have done a little research and this makes the most sense.
    just hope I haven't screwed up the new starter too much from it binding up and me giving it 'love taps'
    cheers delcowizzid and hdtkid, will have a look this arvo and hopefully all is well.
  15. #15
    zelby11 is offline Banned
    SCOOTER
    Jan 2011
    NOWHERE
    Sep 2009
    Broome
    "love taps" on the new reduction drive starters, breaks the permanent magnets in the starter fields.....So be carefull.
  17. #17
    VS Exec
    Jan 2007
    Adelaide (South)
    well, although this is going to make me look extremely stupid...
    turns out it was just a loose earth lead to the starter
    I discovered this only after taking off the flexplate cover to look at the 'stuck' starter, realising that it wasn't stuck at all. jiggled the earth lead a bit, and away she went.
    guess this just reinforces that old addage, "check the simple things first".
  1. [VIC] NEED HELP ASAP...its pissing me off lol
    By bedo89 in forum General
    Last Post: 17-10-2010, 06:13 PM
  2. Coolant pissing out after changing tensioner
    By bennoc in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-06-2010, 09:28 PM
  3. vs clubby problem pissing me off
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-10-2009, 05:52 PM
  4. Typical 5ltr - pissing out oil.
    By Niggadore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-10-2009, 08:30 PM
  5. Pissing in a shot glass
    By Sphinx in forum Jokes/Humour
    Last Post: 29-09-2006, 04:35 PM
