Results 1 to 16 of 16
Thread: vs wont change gears need help
    95 VS SS 5L Commodore x chaser
    Feb 2011
    Roxby Downs
    Unhappy vs wont change gears need help
    hi im new to the site i just brought a vs ss x chaser i got a flat battery put a charged batt in and now my auto wont change from 1st unless i fog it and the idle is up and down i got a mate to check the computer it comes up as code 12 i have been told to disconect the batt for about 10 mins then start it up hold it at 3000 rpm for a few minutes then drive it for about 50 kms to calibrate the computer is this true and how can i fix this problem it was running fine b4 i got a flat battery
    need help on this as i need my car to go to work
    cheers shaun
    D22 St-r Navara
    Dec 2010
    perth
    Feb 2011
    Roxby Downs
    no i brought it private i have had it about 2 months and was running great until i got the flat battery
    James39's Avatar
    James39 is offline Gave up on VL's
    1995 VS Acclaim & 1992 Holden Barina
    Jul 2009
    Newcastle NSW
    Is the alternator working? Might be the reason for the flat battery.
    My car would not change gears when my alternator failed as there was not enough power for the transmission.
    Revs going up and down sounds like the TPS
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    Quote Originally Posted by htmunro350 View Post
    is everything done up tight on the battery>? are the battery lead ok?
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    Feb 2011
    Roxby Downs
    yes alt is fine leads are tight still need some one who has had this problem to help me
    Feb 2011
    Roxby Downs
    please help some one must found a easy way to fix it i have checked the basic stuff as iv built a few motors but no injection stuff with computers even my mate that has this type of car says its something simple just carnt put a finger on it
    code 12 its telling us
    this is giving me the sh* ts as the local work shop is a major rip off and we are in the desert
    PLEASE
    shaun
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Well it would either be to the fact that is not enough power (Battery going flat due to no charge from the alt) or the TPS (Throttle Position Sensor) need to be replaced.
    Feb 2011
    Roxby Downs
    and will this cause my idle up and down and gear changes to be up to sh*th ??? when the computer is telling us theres nothing wrong ????
    shaun
    James39's Avatar
    Jul 2009
    Newcastle NSW
    If the TPS is not working the gears will not change. it would be in limp home mode, same as when there is not enough power for the trans.
    Just a small question for you, does the motor stop when you disconnect the battery terminal?
    Feb 2011
    Roxby Downs
    when i flog it through the gears seems to run fine but flogin it seems wrong because it goes like hell any way and floggin it at hi revs is not good
    James39's Avatar
    Jul 2009
    Newcastle NSW
    Also check the fliud level on the transmission. this needs to be done while the motor is runing and when warmed up.....
    V6 VR Berlina - Stock standard
    Sep 2006
    Brisbane (Southside)
    You should just need to pull the main engine fuse in the engine and wait a minute before replacing it to reset the computer.
    Driving the car after will allow the computer to pickup the faults it can so you can read them later. 'Calibrating the computer' sounds irrelevant unless you want to know your fueld consumption - although I'm not expert on that.
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    Its sounds like a charge problem or a drain i would go over evry inch of the alt system chech the charge rate in volts and apms . A tps fault wold laso give you this problem also dose your speedo work? If not it could also be your speedo sensor on the back of the box!
  15. #15
    Feb 2011
    Roxby Downs
    Feb 2011
    Roxby Downs
    i took the car for a drive for about70-80 ks gear changes are better but not a 100% and idle is still high
    any idears guys as im starting to get realy p* ssed off with this and not fault lights coming up on the dash
    PLEASE HELP IT MUST BE A SIMPLE PROBLEM
    CHEERS SHAUN
  1. !change of top speed in gears when fitting 3.7 diff gears.!!??
    By slappedvr in forum V6 Development And Modification
    Last Post: 30-01-2010, 09:54 PM
  2. Vz wont select any gears
    By Shorty1991 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-01-2010, 10:52 AM
  3. Wont change gears in drive
    By Kernal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-08-2009, 11:10 AM
  4. Car wont change gears, holds gears, and rough changes
    By pedrotski in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2008, 06:35 PM
  5. how do I change diff gears
    By HDT_aero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2005, 10:43 PM
