There are a couple of down sides to either solution.
Duel mass downsides
1. EXPENSIVE!!!!
2. If you start to add power (engine mods) the life of the flywheel gets shorter very quickly.
3. If you get the flywheel HOT (bad clutch control) the life of the flywheel gets shorter very quickly.
4. If you like to have spirited drives, legal of course, the life of the flywheel gets shorter very quickly.
5. Limited clamping pressure on the clutch plate.
Billet flywheel downsides.
1. NOISE. You will get a lot more audible noise from the gearbox, this is a little annoying, but normal for the GETRAG box.
2. See number rule 1
Duel mass upside
1. NOISE. These keep the GETRAG nice and quite.
2. See rule 1.
Billet Upside.
1. Can be machined if you need to.
2. Can handle more HP.
3. Can handle larger clamping pressures.
4. Could keep going on but, you should be getting the picture by now.
When you do things right, people won’t be sure you’ve done anything at all,,,,,,,,,
353RWHP L67 VS S Pack 6 Speed
Kalmaker Tuning Software N03 N04 N05 N06 N07 N08 W00 W10 W20 W21 W30 W31
W40 W41 W45 W46 W50 W51 W55 W56 W81 W85 W86 W91 W95 W96
