hey i have a 94 vr and my mate hit a little pole not long ago. because i dont currently have a license i want to fix it myself so i want to know how to replace the driver side rear quarter panel. thanks for your help
post it in here....... Spray Painting and Panel Beating .........use the forums for the type of issues you have(makes life eaiser for you and other members) welcome to f/c............cheeeers
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
they are welded on.
will need cutting off, and then rewelding. then have to get it sprayed.
also, on a side note, don't post again it Spray Painting and Panel Beating, if you want it there instead, report the post, and get an admin to move it. Stops the forums getting filled up with double posts.
