okay sorry if this is in the wrong section
couple months ago i brought a vr and have noticed a few problems that seem to be common in vr vs etc
so far the air conditoning doesnt work, hopefully just needs a re gas
and the sway bar links are rooted, there getting replaced very soon and also need to replace the control arm bushes
is there any other problems i should look out for?
thanks for that
sorry if i posted in the wrong section or should of looked first
only started using the forums lol
We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
just discorved nearly all the bushes in the rear a rooted
this should be fun to replace lol
Usually the front bushes wearout quicker than the rear so I would check the front bushes also,make sure you put on poly performance bushes they last forever
Sorry mate I just realised you mentioned the front ones
yer the front needs replacing to, i went and got the whole front swaybar linkage when i brought the rears to
hopefully i dont find to many suprises with the front as i did with the rear
you might also need a new pan hard rod on the rear
its got irs
goood luck
