Results 1 to 19 of 19
Thread: bonnet cable works when it wants to!
    Vs excuetive
    Jan 2011
    Default bonnet cable works when it wants to!
    ok, so i pulled the bonnet release and the bonnet clicked and it didn't open its been doing it for a while now, the bonnet cable just works when it wants to, is there a soloution? would the cable need to be replaced?
    Hangman's Avatar
    Hangman is offline Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Cable is probably stretched. My VP needs someone pushing down on the bonnet while you pull the release to open it.
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    Vs excuetive
    Jan 2011
    commodore
    Aug 2009
    australia
    either replace the cable or hitting the bonnet in the d/s corner as youve got the lever pulled usually opens it.
    Vs excuetive
    Jan 2011
    commodore
    Aug 2009
    australia
    just disconnect it from the handle you pull disconnect it from the radiator support/latch and pull it through the firewall first taking note where it is routed so when you feed another through so you know where to run it, but now i think about it you should be able to just loosen the screw clamping the cable to the radiator support and pull the cable to tension it a bit and retighten, id try that before you waste money on a new cable .
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    THERE IS A SMALL ROOM FOR AJUSTMENT) if it aint broken)
    Quote Originally Posted by mwhit43 View Post
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Try some grease on the lock pin. The old stuff dries out and the bonnet wont pop open.
    This extra friction doesn't help the cable!
    Hangman's Avatar
    Jan 2010
    If it's at the stage where you have to push on the bonnet to open it, it will break sooner or later. I'm on my second cable in the VP, but I replaced it with a freebie that has the same problem. Might buy a new one when this one goes.
    Good point about greasing it too.
    V6 VR Berlina - Stock standard
    Sep 2006
    Brisbane (Southside)
    Yeah, my VR gets stuck when I haven't greased it in 6 mths or so - been doing it for a few years. Run around and do your door hinges and bonnet catch etc with some white grease.
    VS Ute S2 5spd
    Jan 2011
    Shepparton
    mine did this, all it was was just the spring on the hood needed adjusting
    1993 Vr Berlina
    Dec 2010
    NSW
    Quote Originally Posted by RX25SE View Post
    thats exactly what i did
    opens no problem now
    zelby11 is offline Banned
    SCOOTER
    Jan 2011
    NOWHERE
    vs commodore
    Oct 2009
    Tamworth NSW
    Sorry about the hijack,but does anyone know what might cause the bonnet not to close unless the lever to open the bonnet inside the car is pulled out first.Ive had this happening the last couple of weeks,It makes it impossible to close the bonnet when Im by myself.I havent had a chance to have a good look at it yet,but I thought Id ask to see if someone here might have had the same problem.It seems like the locking spring in the hole is over too far in the centre of the hole for the tapered head of the locking pin to push it back out of the way as it closes,(if you get what I mean).The pin just hits the spring which stops the bonnet closing until the spring is pulled back to the side of the hole by pulling the bonnet lever in the car.The tapered head of the locking pin should push the spring back to one side, as the locking pin goes into the hole.
  15. #15
    Hangman's Avatar
    Jan 2010
    That's something different mate. You'd think if the spring was rooted it would do the opposite and not latch it properly.
  16. #16
    vs commodore
    Oct 2009
    Tamworth NSW
    The spring has still got heaps of tension,it just seems like its it too far over in the centre of the hole for the taper on the lock bolt head to push it to one side.
  17. #17
    VS Acclaim
    Feb 2011
    NSW
    Just bought a 1996 VS Acclaim this weekend.
    Same problem with the bonnet.
    But putting grease on the latch seem to have helped.
  18. #18
    VS Executive S2
    Nov 2010
    I put wd-40 in the latch hole and tightened up the spring as per image below.
    No probs now!
  19. #19
    Vs excuetive
    Jan 2011
    Since I pulled out my radiator it has been working perfect!
  1. Bonnet release cable snapped how do i open the bonnet
    By S-Pac_Sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 09:07 PM
  2. Help! VL Bonnet Cable Snaped!
    By Chirpstr in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-08-2009, 09:00 AM
  3. 95 lexcen bonnet cable will a VR cable fit?
    By Gazza2005au in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2009, 04:19 PM
  4. bonnet cable
    By zohpm in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-04-2007, 04:12 PM
  5. VN Bonnet Cable Snaped
    By VN-SV-89-LE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-09-2006, 09:49 PM
