Results 1 to 6 of 6
Thread: which gearbox was fitted to the v8 motors?
    vs calais
    Dec 2008
    Default which gearbox was fitted to the v8 motors?
    Hi all,
    just wanted to know which type automatic gearbox was fitted to a vs v8? was it the same as v6?
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    v8.................
    Quote Originally Posted by admir87 View Post
    Hi all,
    4l60E or 4L65E
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
    vs calais
    Dec 2008
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    As far as I know the internals are the same however I believe the bellhousing is different. As the bellhousing is not a removable or swappable part you can only match a v8 trans to a v8 and a v6 trans to a v6. I'm not 100% sure on that though so hopefully some one else can confirm or not
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    4L65e was not fitted to the VR/VS's. So its a 4L60e.
    And yes, the bellhousings arent the same. same box, different bolt up.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    V8 uses the Chev bolt pattern and the V6 uses the buick, or vise-versa (i have the correct way posted here somewhere)
    no not a direct bolt
  1. has anyone ever fitted a getrag gearbox with a hydraulic cluth to a vk
    By patskies in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-08-2010, 10:01 PM
  2. vn ecu used for other motors??
    By defa in forum General Discussion
    Last Post: 02-03-2007, 05:49 AM
  3. VK Motors
    By SiLeNt-SoN in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-12-2006, 09:44 PM
  4. VL motors
    By Just_Ice in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-10-2006, 04:45 PM
