hi guys and girls sorry first post is trouble shooting and not an intro
anyways
the vs will turn over has fuel and spark tryed different ecu tb tps did the water thing on the cas but wont fire into life all the time
if it does fire (not often) you have to run the starter for ages then it is really rough and struggles to go and sucks heaps of air, then if the accelerater is even slightly touch it wants to stall
any ideas please need it running asap
thaks for your help
ps code says its all good
you may think you have spark but the dfi board might be shot, go check for error codes as well, might give you somewhere to start. Checking error codes VR/VS (Revised)
Sounds like the coil pack,my car did the same thing i checked everything but it still was rough,then finally changed the coil pack now it goes perfect
error codes say its ok my mate that owns the car says he tryed a few different coil packs. is there a way of testing them with a multi meter?
