Results 1 to 9 of 9
Thread: Re-locating power steering fluid reseroir
    whitevrboi is offline Just another white vr.
    VR Executive S2
    Feb 2008
    Default Re-locating power steering fluid reseroir
    So as the title suggests I wanna re-locate my p/s reservoir. I have a twin throttle setup that it gets in the way of and before getting the tools out I thought i'd see if anyone has done it before or has any tips...
    I've done a search n didn't get much off that. I know its not pressurized and needs to be higher than the pump itself.
    Would I be able to 'shorten' the reservoir by cutting out a section then plastic welding it back together?
    Any help would be great
    Cheers Jack
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VR Executive S2
    Feb 2008
    Cheers...any suggestions as to where to mount it? also do you know how i would get a hose to fit onto where the box normally sits as its the 3 screws that hold it in place....
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    VR Executive S2
    Feb 2008
    VP Exec
    Jun 2005
    V6? If I recall the punps correctly, you'll also need the VS pump or at least the spigot out of the pump inlet. I think that VR and VS V6 pumps are otherwise identical.
    It will better to mount the reservoir at the same height or higher than it is now although it should work with it a little lower with a positive displacement pump.
    The1's Avatar
    Jan 2005
    Toowoomba QLD
    anyone know if the bolts and holes are in the same place for vr/vs? if so then change the pump and res over would be easy job then.
    VR Executive S2
    Feb 2008
    Yea changing the whole pump and reservoir would be alot easier if any one knows bout the holes lining up?
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Reservoir is on top of the PS Pump in VR, VS have theirs near the Thermofan. Don't think the VS PS Pump will bolt upto the buick motor? Could be wrong.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
  1. power steering fluid?
    By mattgreen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-11-2010, 10:08 AM
  2. Vs power steering fluid q?
    By kritter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2010, 05:15 PM
  3. power steering fluid
    By -ToM- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2009, 09:03 PM
  4. Power Steering Fluid
    By Mickyh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2008, 05:38 AM
  5. Power steering fluid
    By 14000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2007, 05:41 PM
