Results 1 to 6 of 6
Thread: Need advice on VS Commodore
    VS Acclaim
    Feb 2011
    NSW
    Default Need advice on VS Commodore
    Hi guys
    Just bought a 1996 VS Acclaim this weekend.
    A few problems needs resolving.
    Radiator cap turns, but does not come off????
    Temperature gauge does not work
    Ceiling light does not work on switch, or when you open the door.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by Aussies2011 View Post
    Hi guys
    Are you pushing down then twisting off (anti-clockwise)
    Sticky gauges are common problem (try tapping the top of the dash)
    Globe?
    Power is measured in DECIBEL
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    The rad caps need a bit of force down on it, then you can turn it.
    Could be globe or fuse etc etc
    VS Acclaim
    Feb 2011
    NSW
    OK... mystery... went to try again and the cap came off first go. Stranger than fiction.
    Regarding the temperature gauge
    What's the remedy for a sticky needle, besides bashing the dashboard? lol
    As for the fuse box
    Would not you have one fuse only for the whole dashboard?
    Does the ceiling light has its own fuse?
    MAD about Bathurst. http://www.aussies-online.com
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    lol yes, everything has its own fuse basically, check your Interior Illumination fuse. Pop of the fuse cover under the steering wheel, should be a sticker diagram to tell you which one is which.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    The sticking fuel and temp gauge is common to every single VR/VS commodore out there. It's caused by a dry solder in the dash. You could pull it apart and fix it, but is way too much effort really, just love tap the dash when you have to.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
  1. Advice on buying a Commodore
    By dgray in forum General
    Last Post: 15-02-2011, 04:27 PM
  2. [VIC] Advice on buying a Commodore
    By kunalraiker in forum General
    Last Post: 02-08-2010, 08:01 PM
  3. Bought my first commodore, advice...
    By lad79 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2009, 01:10 PM
  4. Need to fix a few little things on my commodore vy, advice appreciated plz!
    By lkorruptl in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-09-2008, 12:48 AM
  5. Advice Buying Commodore SS
    By Sarkis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2006, 01:34 PM
