Results 1 to 25 of 25
Thread: vr v8 efi to carby
    vr 355 man ute
    Jan 2011
    perth,wa
    Default vr v8 efi to carby
    hi all i want to convert my 94 vr 355 from efi to carby has anyone done this.
    VL Wagon
    Aug 2010
    Adelaide, Australia
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    Any reason why you would want to go back to a Carby? I think it will be illegal due to emission laws.
    However you can get Fuel Injection Carby setups if you want to down this path.
    Yours Kindly,
    Jim
    VR_Acclaim is offline Banned
    Vr acclaim
    Jun 2010
    Efi never sound the same to carby, I'm buyin a bs senator with dual 1000 Efi style demon carbs,,, sounds heaps better to when it was a full Efi 355
    VR Executive
    Jun 2010
    Rockhampton
    i had aVG ute long ago with a 355ci Stroker,we ran a carby.Not sure what the rules are now,but as long as we had the same or less emissions as the EFI setup,it was fine.But thats prob changed of late
    The Daily:6/93 VR Executive SedanVQ V8 Long Range Tank L3 Dash Conversion VR Calais Leather Seats VR II Steering Wheel VTSS Mags Aqaumarine in Colour
    The Weekender:6/07 BF XR8 6 Spd Manual Sedan Ego Paint Pedders Coilovers Adj.Swaybars Shelby GT500 Rotating Assembly 2800lb Twin Plate Yella Terra CAI FPV Gauge Pod Full Sports Leather Interior
    Tuned by Glenmore Motors,Rockhampton
    -345RwHp,13.8ET with crappy tires and bulk wheel tramp
    Vr Wagon
    Apr 2010
    Want to register it?? Then you have to stay EFI or pass the incredibly expensive epa tests that prove your car produces less polution than it would if it were efi (almost an impossible task).
    But hell if you dont want to register it you should be sweet a blue carby manifold should fit I think then just put of an appropriate sized carb. Along with getting rid of any unneccisary efi hardware of course/
    vr 355 man ute
    Jan 2011
    perth,wa
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    "wire" a carby up? If you have no idea at all you're wasting your own time and everyone elses. Take it to a mechanic.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    vr 355 man ute
    Jan 2011
    perth,wa
    i just want to know has anyone done this conversion before and whats involved like do you have to keep the ecu for the dash as im got are level 3 dash mines are manual so i don't need to worry about controlling the auto
    Feb 2004
    NSW, Australia
    Interesting concept, electric shifting box with a Carby setup that doesn't require an ECU?
    The VRs were the first of electronic shifts.
    You would need to look out getting a gear box out of a VN/VP to do Carby or go Manual.
    Then you have to do a transition between your speed sensor, revs to your dash, unless you put in a custom dash which would look cool to match your custom build.
    I seriously think you are going to have issues with emission laws, Full on Carby on a model that was brought out with EFI, in N.S.W. I couldn't see that happening as I said before you can get EFI carby setups.
    Good luck with your project.
    Yours Kindly,
    Jim
    Nov 2008
    Smithton, Tasmania.
    YOU CANT LEGALLY DO IT.
    There is a good reason Holden went to EFI.
    It will cost you about $2000 to do it and then you wont be able to drive it on the road.
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I remember someone asking about putting a carb on a VN V6 because they came out on earlier models in the states and someone saying that the fines can go up to $10000 for tapering with emissions if caught?
    Good luck anyways!
    VR Executive
    Jun 2010
    Rockhampton
    i did it in my VG ute(note-this was in QLD).yes it is possible,and yes,it cost a paycheck to get it passed.Hell,there is a VS V8 Calais up here,that runs a carby with filter thru bonnet.And before anyone says "don't you know the difference between TBI & Carby",this thing IS A CARBY,fully registerd.you can legally do it,if you have the money and time to do it BY THE BOOK.
    When i looked to do it to the ute,Engineer at the DOT Qld said it only had to meet GMH Emissions for that size motor (EFI 5Ltr),or put out less emissions then then the stock 5ltr(we went off VN 5ltr emssions card).
    I also put twin cats on the ute aswell,so it is possible,yes it will cost a bit,but really,who gives a S%^t,as i work on drill rigs for a living,and i can do what ever i want(specially after someone says its not possible)
  15. #15
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by soop View Post
    I agree,a carburettor will never give the same or better emissions as EFI will,so it will never pass emissions tests to pass rego.I know of people who have looked into this before (in NSW anyway),and its just not legal.Youve only gotta look at the pollution gear fitted to a VL commodore compared to a VN,on the VL theres pollution gear systems everywhere,the EFI -and full engine management was responsible for way less pollution equipment being used on the VN.It just shows how clean the EFI engines run with full engine management.
  16. #16
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Quote Originally Posted by aqaumarinevr View Post
    i did it in my vg ute(note-this was in qld).yes it is possible,and yes,it cost a paycheck to get it passed.hell,there is a vs v8 calais up here,that runs a carby with filter thru bonnet.and before anyone says "don't you know the difference between tbi & carby",this thing is a carby,fully registerd.you can legally do it,if you have the money and time to do it by the book.
    When i looked to do it to the ute,engineer at the dot qld said it only had to meet gmh emissions for that size motor (efi 5ltr),or put out less emissions then then the stock 5ltr(we went off vn 5ltr emssions card).
    I also put twin cats on the ute aswell,so it is possible,yes it will cost a bit,but really,who gives a s%^t,as i work on drill rigs for a living,and i can do what ever i want(specially after someone says its not possible)
    pics??????????
  17. #17
    Feb 2004
    NSW, Australia
  18. #18
    Mar 2008
  19. #19
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Go hard man, its not like you have any scheduled safety inspections to worry about.
    And of course its possible to tune a carbed engine to the same emissions standards as EFI under set conditions.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
  20. #20
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    Quote Originally Posted by Andrew426 View Post
    Its bloody impossible to tune to the same emissions or less than efi - thats why we have it to pass emissions testing - maybe if you went down the path of E85 you might have a chance. The problem is today that everything is going electronic & relying on the sensors for all sorts of things. The auto relies on the engine sensors includeing throttlebody - so a gearbox replacement would just be the start - it would cost a lot more than 2k as well - shakes head ...
  21. #21
    Jan 2008
    Quote Originally Posted by bpefi View Post
    Its manual.
    And you only have to tune it to run like that for your emissions test.
  22. #22
    Nov 2009
    Bundaberg
    Its manual.
    Like I said you cannot tune a motor to the same emissions as EFI - you do not have the control over mixtures - that is why they have EFI because it gives them greater control than a carb & dizzy - doesnt matter if it is a manual. If you had to do an emissions test "properly" you would fail every time - why do you think manufacturers spent millions of dollars developing this stuff - not for fun I can assure you
  23. #23
    Jan 2008
    Yes it does matter that its manual, you were going on about how the auto trans needs a TPS and everything to function correctly. But its manual. So it doesnt.
    Im not sure what kind of conditions the emissions tests are done over there, but I suggest OP borrows/buys an exhaust gas analyzer and winds the idle mixture right back till the carbon monoxide % is low enough to pass. Doesnt matter if it runs shit or is completely gutless, he can retune it after the test.
  24. #24
    Nov 2008
    Smithton, Tasmania.
    good luck getting carby to run as clean as EFI. Its possible sure. But so is traveling to mars.
  25. #25
    Nov 2009
    Bundaberg
    It will fail straight up on evaporative emissions - but give it a go - all this for a sound..... OMG
  1. swapping Jets from starfire carby to 202 carby
    By RippleEphex in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-06-2010, 02:01 PM
  2. HELP!!! EFI Or Carby????
    By MY_84_VK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-04-2010, 07:24 PM
  3. New Carby vs old carby
    By zaczac in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-03-2010, 01:02 AM
  4. carby
    By quick308 in forum General
    Last Post: 10-07-2006, 11:14 PM
