Results 1 to 11 of 11
Thread: few issues after doing a lvl 3 dash upgrade
    despo's Avatar
    despo is offline V Fast S furious
    vs series one
    Jun 2009
    Default few issues after doing a lvl 3 dash upgrade
    was just putting it all back together today when i realised a few things
    1. everything works well dash wise except when i indicate... it indicates twice as fast and also sets off the fuses making them rattle and a long beep noise
    2. the car doesnt seem to fire up either :S so not sure if the dash upgrade has effected this or just because the car has been sitting in the garage for a while
    please help cheers
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Have you disconnected the engine loom plug to fit the ECU wire (yellow black)
    Also check that the 3 dash plugs are up the correct way
    and 3 Dangerous non ABS VN's
    VR Executive
    Jun 2010
    Rockhampton
    if you have a spare hazard light button,try swapping it.also check your indicator bulbs aren't blown.Also what Green said(way of mine was upside down,and beeped and stuff)..
    The Daily:6/93 VR Executive SedanVQ V8 Long Range Tank L3 Dash Conversion VR Calais Leather Seats VR II Steering Wheel VTSS Mags Aqaumarine in Colour
    The Weekender:6/07 BF XR8 6 Spd Manual Sedan Ego Paint Pedders Coilovers Adj.Swaybars Shelby GT500 Rotating Assembly 2800lb Twin Plate Yella Terra CAI FPV Gauge Pod Full Sports Leather Interior
    Tuned by Glenmore Motors,Rockhampton
    -345RwHp,13.8ET with crappy tires and bulk wheel tramp
    despo's Avatar
    vs series one
    Jun 2009
    mmm kk... ill have to look at the dash plugs tomoz fair sure their all up the right way :S and with the black and yellow wire all i did was dissconnected it from its original loom and plugged it straight into my body loom ( was the what i was ment to do ??? ) indicator bulbs work fine to
    88GreenVN's Avatar
    Jun 2006
    The loom plugs should have pink black wire top left on the left and middle plug and orange white top left on the right plug (except for the speed alert looms that have a light green wire in the left plug and then the pink black)
    What loom have you installed? if it's a level 3 loom then you will have issues with the lights as they are wired differently to the L1 &L2 looms. The A/C is also wrong with the executive cars as they dont have climate control in the cars as the Calais has.
    despo's Avatar
    vs series one
    Jun 2009
    ok i might have to pull them apart tomoz and check it out hopefully its that easy
    um its one from a vr clubbie so guessing its a lvl 3 loom
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by despo View Post
    are yes - that should be OK then.
    despo's Avatar
    vs series one
    Jun 2009
    Quote Originally Posted by 88GreenVN View Post
    ok sweet as then so its either i have mixed up the 3 dash plugs or because i disconnected the exterior lights.. also by doing the lvl 3 upgrade any of this effect starting the car ??
    88GreenVN's Avatar
    Jun 2006
    The only time it effected the starting for me was I forgot to plug the engine loom back in after fitting the yellow black wire into the plug.
    The HSV L3 looms are a L2 with the 4th plug grafted into it factory style. So it should be OK if you have plugged it in the same way it came out of the HSV car.
    despo's Avatar
    vs series one
    Jun 2009
    okk sweet yer didnt touch anything around the ECU was able to plug the yellow and black wire in without touching anything else and on the otherside fairly sure thats all connected properly so that just means i have another issue aha
    despo's Avatar
    vs series one
    Jun 2009
    ok just had a quick look and all were in the right place expect on the left plug mines has the green wire first so its a speed alert one.. does the mean anything regards to my problem ??
  1. Vp Dash Upgrade to Level 3 Vs Dash
    By Loud N Proud in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-01-2011, 07:06 PM
  2. Dash upgrade
    By tiersum in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-03-2010, 09:56 PM
  3. Need HELP! need someone to do my Lvl 3 dash upgrade
    By muggo05 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2009, 12:51 PM
  4. Dash upgrade?
    By Cav in forum General Discussion
    Last Post: 01-11-2006, 08:43 AM
  5. VY II Upgrade Dash
    By RacerX in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-03-2005, 09:06 PM
