Results 1 to 12 of 12
Thread: K&n flat panel air filter or ryco flat panel cant decide
    vs clubsport
    Jan 2011
    sydney
    Default K&n flat panel air filter or ryco flat panel cant decide
    Hey guys im due in buying just a flat panel air filter not sure if i should stick with the cheaper filter or pay the extra for k&n i heard they clog up sensors due to oil use cleaning i know its bull i also think its a myth
    any ideas would like to know thanks its on a vs v8
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    Just stick with the standard paper filter and change it when it gets dirty.
    You are unlikely to notice any performance difference with the K&N panel filter.
    muttley383
    VS ute, manual s-pack
    Apr 2010
    i recently brought one for a vs ute ecotec and the diffrence was felt straight away and got better fuel usage since i put it on. havent had any problems with sensors yet.
    zelby11 is offline Banned
    SCOOTER
    Jan 2011
    NOWHERE
    EH Holden, VS Ute
    Nov 2008
    going form an old dirty cloged up paper filter to any new filter will do wonders for you economy and have a differance... there is little difference between a new plain filter and a k&n filter... apart from the price...
    most people see their street commodore as a high performance racing machine worth 4 times as much as it really is... when really, its just an everyday driver.
    id probable even go so far as to say any noticable differance between a new K&N and a new standard filter would be more so a placebo...
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Ryco...
    K&N is expensive shit. People just think they're good because the pay a fortune for them. Ryco does exactly the same job.
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    I just got a Lukey one for $43, they claim better air flow and better filtering that K&N. Also as they don't need any oil you arent going to have a problem under oiling it and sucking in dirt to your motor or over oiling and restricting air flow (also oil gets on your MAF and makes the car run like crap)
    I don't have any problem with Ryco and would probably use them again over K&N, I had K&N filter on my old car but it was already in it when I bought it.
    The only reason I bought Lukey is because its about the price of 4 cheap ones but is reusable, the shop I bought it from sells more of them than standard filters now.
    Best RPG ever
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    I like how all the idiots in here are saying K&N is better. The advertising sure pays off. Just because they got told K&N is better, means that K&N is better, then bam, they jump in the car and placebo effect takes over. Or even if they realise that it isnt any faster they still say it is, just because they waved goodbye to about $90.
    Bottom line is you wont notice it at all. Dont believe the performance hype, it wont make it faster. Buy it if you never want to replace another air filter but besides that forget it. It made my fuel economy slightly worse (tested! not placebo crap), and makes the sucking air intake noise louder. It also gets filter oil all inside your manifold.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VT
    Apr 2005
    QLD
    Anyone suffering from oil on your MAF meter or in the manifold is over-oiling the filter.
    Beauty of oiled filters is they turn contaminants into filtering media as they become oil-soaked themselves.
    I've used both K&N and Finer Filters, out of the 2, K&N is a lot cleaner.
    If you want simplicity, get a replacement Ryco filter.
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    so if the filter from the factory is apparently over oiled and the oil has got in the manifold, what does that say about it?
    The hall of fame:
    ಠ_ಠ
    Nov 2008
    Smithton, Tasmania.
    K&N's do filter better.
    But the re-oiling kits are still 4x the price of a Ryco...
    VS ute
    Jan 2010
    townsville
    The way i see it. If an aftermarket panel filter provides better flow this will result in less filtering
  1. A K&N panel filter is this better than an air pod
    By vyaw2003 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-02-2011, 02:16 PM
  2. Panel Filter vs CAI (for V6)
    By mc. in forum VE Holden Commodore (2006 - ?)
    Last Post: 19-12-2010, 01:03 PM
  3. [SA] FS: VN-VS K&N Panel Filter
    By exec24 in forum Parts And Other Items For Sale
    Last Post: 25-12-2009, 11:42 PM
  4. K & N Panel Filter
    By pk2k78 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-07-2008, 10:23 AM
  5. K&N flat panel filters
    By coolvxss in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-05-2006, 12:02 AM
