Results 1 to 4 of 4
Thread: Vs thermo fan removal?
    Vs excuetive
    Jan 2011
    Question Vs thermo fan removal?
    I've searched this forum for the removal of the vs thermo fans. Can somebody please help me? I'm 15 and I need to replace a vs radiator and need the thermo fans out! Please help me!! If you can, can you post up some pictures to show me what I'm looking for?
    Thanks in advanced
    Disturbed_vegeta's Avatar
    Disturbed_vegeta is offline I'd Prefer To ROAR!
    Vs Statesman, Vr Senator 185I
    Dec 2005
    Burpengary
    i havent owned a ecotec for a few years but from memory, But all you have to do is get the radiator out. First remove the coolant hoses (2 big hoses) and the trans lines (if a auto) then remove the clips that hold the radiator in(use pliers or a flat blade if necessary) then unclip the power steering res(jsut lifts out) then theres a plug under that mount, unclip that. then pull the whole thing out...then 4 10mm bolts the fan should come off..
    Hope it helps.
    Vs excuetive
    Jan 2011
    stuartl1989 is offline Its not your's
    96 VS
    Feb 2011
    Caboolture
    removing the thermo fan is pretty damn easy! its just a bolt in each corner and a plug (or 2) on drivers side and then wiggle wiggle........
  1. VE SV6 head unit removal and head uni fascia removal
    By IGNITIONSV6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 08-04-2011, 05:45 PM
  2. Thermo fan for VK
    By craigvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-12-2008, 02:44 PM
  3. WTB: au thermo fan
    By beefcream in forum Swap / Wanted to Buy / Trade
    Last Post: 21-03-2008, 10:08 PM
  4. Vn thermo fan
    By kasey375 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2006, 09:40 AM
  5. Thermo fan into VS
    By scj in forum Electrical Wiring / Questions
    Last Post: 07-02-2005, 09:51 AM
