Results 1 to 4 of 4
Thread: VR engine into VS
    VS Executive s2
    Feb 2011
    Albury
    Default VR engine into VS
    hi everyone, just wondering if a VR engine would fit into a VS and if its just a drop in and go method or if there is alot of work involved
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Physically, yes, but the wiring, pcm management and bcm etc. is all different and would also need to be changed. HOWEVER, this would not be legal and pass any inspection etc as you cannot put an older commodore motor in a newer body. It must be replaced with an engine option that was available in the vs body or alternatively a newer motor with engineering etc. Basically you're best off to replace it with another ecotec V6
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    And exhaust, fuel lines and VS motors cost about the same VR ones so doesn't make financial sense.
    justbad4you's Avatar
    justbad4you is offline IF YOR NOT A HOLDEN
    97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
    Sep 2005
    MELBOURNE S/E BAYSIDE
    i put a vs eng back into you vs...less hassles and the ecotec is better on fuel than the buick
    Quote Originally Posted by vsowner94 View Post
    We ALL HAVE 1 THING IN COMMON:THE RELENTLESS PURSUIT OF GRIP
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. VS Ute Engine just fitted but engine light coming on and not going into overdrive
    By MX_Leigh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2010, 04:53 PM
  3. vs 304 (5.0L) engine wiring diagram - engine dyno runs
    By chez00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 03:00 PM
  4. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
