Results 1 to 6 of 6
Thread: vs v6 starter motor not engaging
    vs v6 auto sedan
    Feb 2011
    newport
    Default vs v6 starter motor not engaging
    Hi guys,
    can anyone help me with my vs? It's having starter motor trouble.
    Descriction: The starter motor doesn't seem to be turning the motor
    over.It will turn the motor a bit then just spin,sometimes it grabs a bit
    more but not enough to start the motor. I changed it out six weeks ago
    because it was doing the same thing(the original starter)but in that case
    it degraded over a period of time(about two months),were as the new one
    gave up almost straight away(started three times after symptom returned).
    The motor also has a problem were on start up the yellow engine light comes
    on and the motor runs rough,(A mechanic told me it was the water temp sensor)
    I turn it off then start again and it runs fine and no warning light.I thought this
    double use of the starter was the cause of the original starter falling but now I'm
    sure.Has anyone had this problem or can help? Regards King monkey
    VS ute
    Jan 2010
    townsville
    check the teeth on the flywheel mate?
    run a diagnostics test in regards to your warning lights
    zelby11 is offline Banned
    SCOOTER
    Jan 2011
    NOWHERE
    What about the cas,check all the elects,check the coil pack in most cases their the culprat
    SCOOTER
    Jan 2011
    NOWHERE
    If the starter is always failing then there is another problem there is no way you can have all those starters braking down
    VS ute
    Jan 2010
    townsville
    SCOOTER
    Jan 2011
    NOWHERE
    Surely its got to be electrical how unlucky would anyone be to have all the starters stuff up?
  1. [VIC] WTB Starter motor to suit VC Blue motor 202.
    By Drewie in forum Swap / Wanted to Buy / Trade
    Last Post: 11-05-2009, 01:09 PM
  2. VR to VS starter motor
    By stockyvrcalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-04-2009, 08:57 PM
  3. Starter motor?
    By VT SERIES II in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-12-2008, 02:55 PM
  4. starter motor vn v8 - vn v6
    By prjacksonau in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2008, 12:58 PM
  5. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
