Results 1 to 10 of 10
Thread: Major dramas! Please help!
    VXII Berlina 2002
    Feb 2011
    Central Coast, NSW
    Question Major dramas! Please help!
    (Regarding my V6 automatic VS 1996)
    So the other week, my gearbox starts playing up and I got error code 81 from the computer, which is 2 - 3 Shift Control Solenoid Fault.
    Anyway, I've still been driving around with only first and third gear (which I have to do manually), which I know isn't good... but I need to drive! I re-ran the computer error check and it came up with the following:
    Code 32 - Manifold Air Flow Sensor
    Code 66 - 3 - 2 Shift Control Solenoid Circuit Fault
    Code 67 - TCC ON - OFF Solenoid Control Fault
    Code 81 - 2 - 3 Shift Control Solenoid Fault
    Code 82 - 1 - 2 Shift Control Solenoid Fault
    Code 83 - Torque Converter Clutch Circuit
    Can anyone explain some of these problems to me and let me know if I'm in a world of hurt?
    I can pretty much gather that I need a new gearbox... but is there anything else?
    Cheers!
    "A drunken man's words are a sober man's thoughts."
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    I dont actually think you're in for a new gearbox. Apart from a new MAF sensor it only looks like it only needs new solenoids which are about $80 a pop. These are electrical plug-in sensors on the inside of the tranny pan and they go pretty often. It's kinda rare to see them all go at once though.
    You can replace them yourself if you can manage to drop the pan, they're only held in by circlips but dropping the pan is not as easy as it sounds.
    You can watch this youtube video:
    http://www.youtube.com/watch?v=OGckmJK2rNQ
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VXII Berlina 2002
    Feb 2011
    Central Coast, NSW
    I got a quote from an auto trans joint, just to fix one solenoid and it came back $385. I can get a second hand (decent) gearbox put in for $400 or so, so I guess I'd rather just do that.
    Is there much of a drama to put a new MAF sensor in?
    VXII Berlina 2002
    Feb 2011
    Central Coast, NSW
    Oh, I should also add, I asked about how much just the solenoid was on it's own, so I could do it myself and he said $185 a pop!
    vs commodore
    Oct 2009
    Tamworth NSW
    Check out the link.Its just a site I found on google,but it shows the prices of these parts to give you an idea of what you should be paying for them,and its nowhere near $185.
    4L60E,4L65E, Switches & solenoids, Bulkpart transmission parts
    Id just buy them from a place like in the above link,then buy a 4L60E auto transmission filter service kit as well,get 5 litres of dexron 111(3) trans fluid,and do it yourself.Have a look at some of the videos on youtube-(4L60E) to get an idea of what you have to do,its easy anyway.Then once theyre fitted,replace the filter and filter seal with the new ones from the kit, fit the pan with the new pan gasket from the kit, and fill er up with fluid.Too easy.The trans filter kits are around $25, and roughly the same for the 5 litres of fluid.
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    Quote Originally Posted by oldmateadz View Post
    Nice business to get into... click on brett_jjj's link and order them for $15 each.
    Also, no second hand gearbox for $400 is decent, they just tell you that. A wreckers I presume? they really have no idea what condition the box is in.
    The hall of fame:
    ಠ_ಠ
    VXII Berlina 2002
    Feb 2011
    Central Coast, NSW
    Bargain, can't believe the mark up on such a small, cheap part. Pisses me off a bit!
    The gearbox was offered to me by a mate, not from a wreckers... but either way, if you guys really think this is best way... I'll do that.
    Would solenoid faults be the cause of the box making a loud grinding noise too, even in neutral.
    What about all the circuit faults, the solenoid and torque clutch converter? And the manifold air flow?
    Cheers.
    vs commodore
    Oct 2009
    Tamworth NSW
    Cheers.
    Have you checked the wiring and connectors that go to the transmission and engine sensors etc..Dodgey wiring or connectors can also cause error codes to log..
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    you have popped the trans fuse in the fusebox under the steering wheel its why maf etc is coding as well same fuse does maf and all the solinoids in the box fit a new fuse LOL
    VXII Berlina 2002
    Feb 2011
    Central Coast, NSW
    Quote Originally Posted by delcowizzid View Post
    That was the first thing I did. All the fuses are fine.
  1. dramas with my vr
    By markovr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2010, 08:52 AM
  2. a few vz dramas
    By markovr in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-10-2007, 07:11 PM
  3. 202 dramas!
    By Joes_meat in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-05-2006, 11:58 PM
  4. air con dramas
    By VTPREDATOR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-03-2006, 12:49 PM
