Results 1 to 10 of 10
Thread: Vs commodore dash light fuse keeps blowing!!! HELP!
    vs commodore ute Series 2
    Feb 2011
    Mackay
    Default Vs commodore dash light fuse keeps blowing!!! HELP!
    hey all,
    Just purchased a 1997 vs ute, I realised while driving it home that it had no dash lights, so the next morning I put a new fuse in and as soon as i turn the parkers or headlights on it blows. I have taken the tail lights out and removed all the bulbs (brake lights,idicators and reverse lights and number plate lights) and i have also cut and taped all the wires for the trailer plug.
    Can anyone help?
    zelby11 is offline Banned
    SCOOTER
    Jan 2011
    NOWHERE
    You have a short circuit somewhere in the wiring,something like this happened to my car once and the problem ended up being in the boot light wiring.What you need to do is take it to an auto electrician,he will test the wiring for you and pinpoint the problem
    Feb 2011
    Mackay
    does anyone else have any suggestions for what I can try?
    My Vs is a UTE
    dont really want to pay an auto elec $200 to look at it and fix it
    Feb 2011
    Mackay
    VX SS
    Jun 2005
    Has is got a aftermarket stereo fitted? Make sure the factory illumination wiring isnt hooked up to anything
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    ^^^ i did that,when i replaced the stereo in my ss,the illumination wire was earthing out against the metal bracket and kept blowing the fuse
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    There will be a positive wire naked somewhere, will generally be in plain sight.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    VT COMMODORE
    Dec 2008
    Usually stuff like thatbis because of a loose wire or build upbof dust. get some electrical cleaner and spray it everywhere
    95 VS Calais
    Apr 2011
    Central Coast
    I dont know if this helps but in my old vl the fuse for the lights kept blowing just after i put a new intrument cluster in it. So i put the old one back in and it worked perfect again, so when i had time i pulled the tacho dash apart and there was a globe in the back where the glass had cracked and the was a small chunk missing and all the plastic around it was melted, no wires were damaged just the plastic surrounding the bulb. The car got written off before i could try puttin a new bulb in the dash and re-installing it but i assumed the bulb was still working to some degree heating up and blowing the fuse for the lights.
    96 VS executive series II 'S pack'
    Jan 2011
    australia
    i have a similar problem. but when i replace the fuse for my dash lights and turn on my lights itll blow my parker fuse. so i either have no parkers or no dash lights
    thank god for speed alert and cruise control
  1. My fuse for the dash lights is blowing (number 1 - 15amp fuse)
    By aussie7 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2011, 06:10 PM
  2. Fuse for the dash lights keeps blowing
    By cypher967 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-06-2009, 07:09 PM
  3. Brake Light fuse keeps blowing
    By b3h3m07h in forum Electrical Wiring / Questions
    Last Post: 25-10-2007, 07:38 AM
  4. stereo and dash light fuse keeps blowing
    By V8commodore_chick in forum Electrical Wiring / Questions
    Last Post: 21-07-2006, 02:03 AM
  5. VN Reverse light fuse keeps blowing!?
    By saint_matrix in forum Electrical Wiring / Questions
    Last Post: 04-06-2006, 08:53 PM
