Hi, im looking at replacing the diff mount in my ss but not sure how,does anyone know how to replace the irs diff mount bush?
By dropping the centre down mate I've recently done mine there not hard but I'll never go nolathaine again though as mine broke in 6 weeks or so, so I went rubber again
how do i go about that though,ive never needed to touch a diff so im not sure what im doing,also how long does it take roughly?
its really easy, id recommend putting a jack under it because is comes down pretty quick when you take the last bolt out (4 in total) alll you need to do is jack up the car, put on stands, put a jack under the diff, under the 4 13mm bolts that hold it to the chassis (located at the back of the diff), then drop the jack, 2 bolts at the back of the diff( im pretty sure theyre 22mm or something like that) then pretty much reverse the process. Should take about a hr max.
