Results 1 to 4 of 4
Thread: Air conditioning problem - short blasts
    VS
    Feb 2011
    Default Air conditioning problem - short blasts
    Hi everyone
    I have a VS and it has a weird air conditioning problem. When I turn the fan on by itself it takes a few seconds to register and then comes on fine. When I press the AC button the fan turns off and comes on every 3 seconds in short 1 second blasts. Just wondering if anyone's heard of this problem before? Could it be a stuffed relay? It doesn't matter what speed I'm going, what RPM, etc.
    Cheers!
    The1's Avatar
    The1 is offline A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I'd reckon on it being the resistor block that controls the fan speed - if the resistive wire is broken, it can make intermittent contact - you can check if this is the fault by turning the fan to HI and if it comes on straight away it will NOT be the resistor block. The fact that it takes a few seconds to turn on without the A/C rules out low gas IMO. Could also be a bad fuse or relay.
    Welcome to the forum too.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Quote Originally Posted by Gibbo123 View Post
    Im only guessing, but I think it may be 2 seperate issues. Regarding the delay, as above, this could be caused by a slow vacuum leak, hence the non-instant response?
    With the AC on, doing its short 1 second burst thing, does it do this the same on all speeds?
  1. VT Air Conditioning Problem
    By agault in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-06-2011, 03:34 AM
  2. VT Air conditioning problem
    By Cobra670 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-05-2010, 06:36 PM
  3. VX air conditioning switch problem
    By surfer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2010, 08:14 PM
  4. Air Conditioning Problem VZ
    By Anfernee0525 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-11-2009, 10:04 PM
  5. VX Air Conditioning Problem
    By tdog in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-02-2007, 09:04 PM
