Anyone got any pics of VS commodores (preferably with stock front bar) with fog or driving light setups? Factory and/or otherwise .. Just wanna see what people have ..
Thanks!
Also, furthermore, is the wiring for the fog lights factory fitted, installed in a VS Calais?
I added the front foggies to my VS exec standard front bar. Had the bezels added when it was in for repair from a minor front end bingle
No pics of it ATM and I can't get any as it is parked at work over the long weekend.
The wiring I made up myself using the Holden diagrams. Not too hard except for the wire from the switch to the relay (through the firewall) and the addition of a relay to the engine relay block. Depending what level car you have, it may or may not already have the wiring there. Easy way to check is to see if there is any unconnected connectors near where the lights would be.
Have fun.....
heres a pic of my vr commo with driving lights
Mine looks like that minus the lower skirt, the red striping and with exec nostrils.
QUOTE (ChRiDDa @ Mar 8 2004, 09:12 PM) heres a pic of my vr commo with driving lights
EEEEEEEEEWWWWWWWWW DEBADGED!!! Sacrilege!
Queensland - The Cruising State
where i work, im constantly hearing ppl having their cars either debadged, keyed or stolen, so i thought id save them the trouble n just debadge it myself! saves them doing it for me
QUOTE (ChRiDDa @ Mar 8 2004, 09:47 PM) where i work, im constantly hearing ppl having their cars either debadged, keyed or stolen, so i thought id save them the trouble n just debadge it myself! saves them doing it for me
Wow, you work at Mt Gravatt too!?
hey guys,
chridda, is that a filler panel or somethin of da sort that holds your drivin lights? if so, where did u pick them up from?
Ive got a vs ute with a nudge bar holdin two fog lights but wouldnt mind some extra drivin lights like that too
LOL .. thanks guys :0
Anyone got a calais and know if the wiring is there in a high-series car? I've got the proper switch to install, and I'd like to install some driving lights .. Anyone recommend a model that fits with the front bar? Or at least, the holden part number if using actual parts to suit ..
Thanks!
I'd be interested in that mounting panel piece too .. looks nice
Is the ss front bar the same as the standard front bar, but with extras? ie fog lights
So can you drill out the standard bar and get the ss fog lights and other attachments and turn your front bar into an ss bar?
Pretty sure the standard bar is the same as the bar with the fog lights ...just has the pieces cut out and the surrounds clamped in.
Any idea of price in parts to do the mod?
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
Plastic surround bits are $14 each from Holden unpainted
And here it is.........
Standard exec bumper with the bits cut out and the fog light surrounds stuck in.
Just ignore the dirt and stone chips.....
Is it easy to do? How much do you have to cut?
As I said above - I had a panel beater do it as the car happened to be there. I rekon it wouldn't be too hard to DIY.
Hey spike:
QUOTE Plastic surround bits are $14 each from Holden unpainted
where did you get these from?
holden?
Do you have a part number tho?
Bracket and light assembly $130 each and bezel about $20 each retail all up with gst included from holden making it about a $300 exercise before painting and electrics ie wiring and switch
Might skim about $30 - 40 if you can swing trade price
Had a quick look today, and there is no real cut out line so would take a fair bit of playing around with. For me its more effort than its worth. If you want them that bad, probably easier just to get a different front bar.
Acquired most bits over time.
Dash switch, engine bay relay block (rather than wire it in) and lights I got from a wrecker pretty cheap.
Bezels from Holden dealer.
Wiring diagrams from gregorys manual.
On my VR SS i have driving lights but when i turn them on the hgeadlights dim. Is there anyone that knows anything about this.
thanks
hahaha, yeah it means theyre too bright! What it really means is that the amount of power in the car isn't enough to run lights and driving lights. Maybe try turning off the 2000W amp? A new battery and voltage regulator should fix that.Originally Posted by newfoundglory
its meant to be like that chief...
when u have your headlights on and turn the driving lights on, they switch to parkers... but when u have driving lights on, and switch on the high beams, u get everything
i thought it was a fault, but i read the manual that came with the car and it said it was suppose 2 be like that![]()
