LPG Gauge, Impco system
Hey guys I've been reading through the LPG threads and cant seem to find an answer, I have an Impco gas system fitted on my V6 ute about 3 years ago, however it has the LED gauge under the trip computer and I was wondering if it was possible to run it into the fuel gauge in the instrument cluster.
Would it be as simple as running the senders from the LPG and the fuel into a relay triggered by the LPG switch to the fuel gauge in the instrument cluster, or would the two senders have a different voltage?
Also I have upgraded to a level 3 cluster, would this be an issue?
Any info would be appreciated
thanks heaps
this is a guide to vs lpg wiring and this show you how to run through fuel gauge and this is the link http://www.apexus.com.au/document/kits/qk102.pdf
thanks peter this is what i was looking for
Glad to be able to help
hey guys im after the same info posted here but for a s1 vr v6
You should try that guide that was posted by peter, i found it was an easy to convert the gauge to the cluster, however i need a different sender from the gas tank for it to work
