Hey guys,
Wanting to know what sort of transmission coolers people are using on the VR Ute.
The Ute has a surprisingly hard shift kit, stallie and cam so the transmission is worked relatively hard. All this has been installed fairly recently but with nil cooler installed.
I believe it has a couple hoses through to the radiator but want to back it up with a decent cooler.
Any suggestions or advice?
Thanks in advance guys
EDIT: Another quick question - Will a VR V8 Wagon Exhaust fit to a VR V8 Ute?? I have heard that the pan is the same but would like to confirm
yeah any of the good brands including davis craig would be good - bigger the better
running a alloy 400x200 here in the vs with transmax oil keeps it at 75c constant, not running it through rad.
this here is similar to what i have, same size and push on connections.
~ NEW 15.5" x 7.5" TRANSMISSION OIL COOLER KIT ~ (eBay item 310293931485 end time 13-Feb-11 19:46:40 AEDST) : Cars, Bikes, Boats
Far out that is cheap. I was expecting a couple hundred dollars. Cheers for the link
What is a good location on the VR - VS with A/C?
I've got a deralie & it's mounted infront of the a/c condenser by 2 metal/flat bar straps that hold it away from the condenser by 3-4cm's right behind the bumper mouth for maximum air flow.
