Results 1 to 3 of 3
Thread: Wagon Towbars - is there a difference between VP and VS
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    Default Wagon Towbars - is there a difference between VP and VS
    Is there a difference between them? We purchased a 'VS Wagon Towbar assembly', and when we tried to fit it we noticed the holes don't line up in the chassis rails. We then noticed that the assembly had VP written on it. Now the wreckers we purchased it from are telling us to drill new holes in the chassis but that doesn't seem right to me. We know you have to drill holes in the boot floor, but drilling holes in the rail seems dodgy...
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It should have the application plate attached to the towbar - it should be welded to the bar...this is a legal requirement as some towbars are rated to 1300KG and others to 2300KG. With no application plate attached, the wreckers are leaving themselves wide open if you tow over the capacity of the towbar and it breaks.
    Vr Wagon
    Apr 2010
    As far as i know it should fit. I know that when I fitted mine to my VR i had to elongate the holes that were there to get them to line up better. How far out are the holes?
  1. What is the difference?
    By EquipedVZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 24-04-2010, 01:33 PM
  2. Difference between VL wagon and sedan springs
    By Kirbs in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-09-2009, 12:12 PM
  3. Difference between VY S1 and S2?
    By Burto89 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-06-2009, 12:03 AM
  4. wagon V sedan size difference?
    By HoldenMad in forum General
    Last Post: 15-10-2006, 11:35 PM
  5. Diff difference sedan and wagon
    By jimiemick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 09:39 AM
