Results 1 to 24 of 24
Thread: 5l knock ensor issue
    VS Senator
    Oct 2009
    Default 5l knock ensor issue
    im having issues with my knock sensor on my senator. the guy i bought it off got extractors put on it and during the fitting stage the knock censor and its wiring got damaged. so the exhaust shop put in a new censor in and cut and shut a new plug on it and ever since then the engine light comes on with a knock censor fault. i have been told that if the length of the wiring to it is alter it won't respond. is that true. any help would be greatly appreciated
    STL17's Avatar
    STL17 is offline Whipit
    VS STATO , VP EX COP
    Aug 2009
    townsville
    Come on people some1 should know
    tuning done by THE1 A+++++ tuner
    And powering it by MACE
    Build it to handle the MANG
    D22 St-r Navara
    Dec 2010
    perth
    wouldnt think 10 cms woul make bugger all difference. new doesnt mean perfect could just be a faulty new sensor
    VT 3.8ltr Berlina Next Car: VZ Calais or VY SS
    May 2010
    check the whole length of the wiring for any more breaks.
    a mechanic working on my car broke the wiring when putting in engine mounts
    check the passenger side engine mount area where the knock sensor wire runs
    VS Senator
    Oct 2009
    ok i checked the wire and there is no break in it. put in another knock censor and the light stays on. been told that the fault light will stay on till the fault is cleared.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    You must clear the error codes to see if the problem is gone. The codes lock in till they are cleared.
    Shortening and legnthing the wires ect..= BS. curcuit legnth makes no difference in this case.
    One thing that may not be apparent is if the wires got stretched and the cores inside maybe broken, but the insulation is still intact. This can usually be found by a very close visual inspectio at any spots where the wire may be broken and feeling the wire by bending it. It will feel extremely weak and limp and hollow if this has happened where you bend it. I highly doubt this has happened, but could have.
    As abaove, new dosnt = garunteed working 100%. The zorst shop would have fitted the cheapest nastiest replacement they could find.
    Reaper
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    check you have a memcal with a filter board for the knock sensor on it :P may have removed a tuned memcal and refitted a stock one with no knock filter when he sold it to you
    VS Senator
    Oct 2009
    the memcal and everything are fine. i got the car off a mate and i no his history with the car. the wire seams fine, it sends power through it when we tested it. not sure on the quality of the knock censor tho. my mate would have got one from his work as he sells automotive parts. the part that was worrying me was the wire. someone told my mate that if the length is changed or anything like that then it will affect the signal.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    wire doesnt matter .make sure he fitted a vn-vr v6-v8 one not an ecotec one or it will still spit codes
    VS Senator
    Oct 2009
    alright cool. i put another one in on Sunday. just waiting to get the code cleared now. went to a place this morning but there scan tool wouldn't read the computer. so went and booked it into a place with a tech 2
    в∞ѕтεכ √&
    Jul 2008
    NZ
    its a VS just dissconnect the battery turn key to where the reds are and push the brake pedal or just wait a few minutes with no battery
    VS Senator
    Oct 2009
    what do you mean where the reds are. do you mean on accessories. will disconnecting the battery clear codes on the vs ecu
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    VS Senator
    Oct 2009
    sweet. auto electrical isn't my strong point so i was going of what Ive been told. i will see if i can get it cleared by taking of the battery lead for a bit
  15. #15
    VrWagz1's Avatar
    May 2008
    wollongong
    Search for info hear on error codes. I know all models vn-r can be cleared by just disconnecting the battery for a short bit. VS would be the same i would think.
    Reaper
  16. #16
    vs commodore
    Oct 2009
    Tamworth NSW
    You can definitely clear the ECU codes on a VS by disconnecting the battery for a few minutes.You dont need a scantool to do this..Heres a link to a post that shows you how to check your own ECU error codes.
    ---Checking error codes VR/VS (Revised)---
  17. #17
    VS Senator
    Oct 2009
    i disconnected the battery but the engine lights still comes up. so im thinking there might still be other issues
  18. #18
    vs commodore
    Oct 2009
    Tamworth NSW
    What error codes does it give you now?That could point you in the right direction if any are set again after them being cleared..
  19. #19
    VS Senator
    Oct 2009
    the codes it is was throwing up(haven't had it on the scan tool to see if anything has changed)was theft deterent signal missing(what does that mean) pressure solenoid (guessing from the shift kitted auto) and the knock censor. the car has only brought up the engine light since the knock censor got broken
  20. #20
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    how did they join the wire? if theres a build up of resistance in the wire it could affect it
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  21. #21
    VS Senator
    Oct 2009
    i redid the join to check it. just twisted the wires together and put some solder on it and then some heat shrink to tidy it up.
  22. #22
    May 2010
    Ive got 2 Brand New Knock sensors here if you want to buy them.
    I bought them to replace in my VT but i took it back under warranty at the mechanic and he re-wired the existing ones to fix the fault
  23. #23
    в∞ѕтεכ √&
    Jul 2008
    NZ
    vt v6 ones are different
  24. #24
    STL17's Avatar
    Aug 2009
    townsville
    fixed yet???? just take the bulb out clint or ill come round and do it for ya
  1. knock knock......whats there?
    By xitekamelion in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2009, 12:43 AM
  2. Vs clubby irs diff knock issue
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2008, 04:40 PM
  3. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  4. knock knock, whos there?
    By blunt in forum Jokes/Humour
    Last Post: 03-11-2005, 06:03 PM
  5. knock knock bloody knock
    By petesvns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2005, 12:39 PM
