Results 1 to 11 of 11
Thread: ####, split my air intake pipe.
    Patti2912's Avatar
    Patti2912 is offline P4TT1
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Default ####, split my air intake pipe.
    I won't say how () but i have split my air intake pipe.
    Not a huge deal, but im now after a new one.
    Have researched stainless steel pipes and have decided that for the most part they are purely for look, with possibly SLIGHT smoother airflow (i apologize if im incorrect),
    Never the less, im after a new one, whether it be another plastic replacement, or upgrade to a stainless one.
    I've searched ebay but can't seem to find too much, can someone point me in the right direction for a new one, and possibly suggest which one id be better off going for?
    Money isn't too much of an issue.
    VR v6 auto with cold air intake, k&n panel, extractors, custom grind cam, custom tuned memcal, exhaust ect. All the common mods.
    Thanks in advance
    Quote Originally Posted by Morton View Post
    You're better off using a 175g can of Masterfoods Wholegrain Mustard. I just measured that, and it's 9.5cm tall. Keep one in your car at all times, and if a police officer tries the "coke can test", you can tell him what I told you
    jharv58 is offline jharv58
    vr executive s1
    Nov 2010
    rockhampton
    commodore
    Aug 2009
    australia
    +1 wreckers or just use what ive got, stormwater plumbing pipe and a couple of bends lol,
    VS S Pack
    Sep 2009
    Patti2912's Avatar
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Quote Originally Posted by Trikky View Post
    why go to the wreckers when you can get them new on EBAY?
    had same problem a couple of weeks ago got this one even though fo VT vit my VS perfectly
    Chris
    Good call about the wreckers, id prefer a new one.
    As i said i searched ebay and couldn't really find much, so you say a VT one should fit as well? No altering it at all?
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    Quote Originally Posted by Patti2912 View Post
    not on a VR, he was talking VS.
    as was said above, could just use stormwater pipe, a 90 degree bend, and paint it all black.
    Patti2912's Avatar
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Quote Originally Posted by wamboin23 View Post
    Oh, the vs is the same as the vt because of the ecotec engine? Got it.
    I'm happy to give the storm water pipe a go, but is this really the best option for me?
    Personally it just sounds cheap and i don't want to half ask it if i could just pay to get a proper intake pipe or something that may work a bit better than a storm water pipe. I may be wrong, im just not looking for a cheap fix.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Why not plate up your intake manifold, stick a couple of 50mm throttlebodies on the top, pointing upwards through the bonnet and keep your air filter hidden under a group A scoop on the bonnet, or alternatively just sticking out?
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    93' Pov-Pac
    Jul 2010
    If you want a cheap fix, just grab another factory L pipe from the wreckers, or see if there is anyone wrecking a VN- VR V6 on here. A mate may even have a spare lying around.
    If you want something that will help performance, find a pipe that is 100% smooth on the inside, and find a way to insulate the outside from heat. It may help to ditch the convoluted connectors and replace them with silicone hose, though it will only make a difference if they are the main restriction in the intake system.
    Patti2912's Avatar
    93 VR S Commodore
    Jul 2010
    St. Kilda
    Post
    Quote Originally Posted by Bizmark View Post
    So what was suggested a few comments above regarding storm water piping, is this the kind of piping your talking about?
    I've seen straight smooth black plastic as air intake pipes before but always figured this was a product that can be bought from ebay, holden, ect, which ideally what i was trying to locate by starting this thread.
    Ill try my hand at making one and see how that goes.
    Thanks heaps for that bud.
    VS S Pack
    Sep 2009
    yeah sorry didn't see that you had a VR no the one I linked to will only work on VS onwards Ecotec
LinkBacks (?)
  1. VZ SV6 Air Intake Pipe
    By richardpalinkas in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-05-2012, 10:38 PM
  2. intake pipe
    By Archers in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-08-2009, 04:28 PM
  3. [QLD] WTB: Air Intake Pipe for VP
    By Friction in forum Parts And Other Items For Sale
    Last Post: 24-02-2009, 04:48 PM
  4. intake pipe
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-01-2007, 11:24 AM
  5. Air intake pipe
    By UTE-ERS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-02-2005, 10:58 PM
